Activity Forums AJA Video Systems Kona LHi residual audio static
  • Kona LHi residual audio static
    Posted by David De vos on August 6, 2009 at 5:56 pm
    Just set up Kona LHi with Mac Pro Harpertown 2.8 eight core running Final Cut 6.0.6. It worked fine for a few days, but now I’m getting a strange residual audio static every I stop the playhead, whether I’m editing, watching in the viewer, or playing back via the timeline. It’s like it’s echoing the last few seconds of audio, but with a very annoying static burst mixed in. It trickles off to silence, but happens again each time I move the playhead. Anybody comes across this? I checked my amp, but I’m getting the static signal into my mixer, which is directly out from the Kona.
    Any thoughts?
    David De vos replied 16 years, 11 months ago 5 Members · 15 Replies
  • 15 Replies
  • Jeremy Garchow
    August 6, 2009 at 7:59 pm
    Are you running your system sounds through the Kona?
  • David De vos
    August 6, 2009 at 8:49 pm
    Yes.
  • Jeremy Garchow
    August 6, 2009 at 8:58 pm
    Try turning that off and see what you get. If you need system sounds through your audio monitors, simply send a cable from your headphone/line out of your mac into your mixer.
    Jeremy
  • Vince Sanchez
    August 6, 2009 at 9:09 pm
    I get the same thing, and I don’t have my system sounds sent to the Lhi. It was bad for a while but its only once in a while now.
    Vince Sanchez
    Intel Quad Mac 2.66
    AJA LHe
    HD link
    OSX 10.4.11
    FCP Studio 2
  • David De vos
    August 6, 2009 at 9:17 pm
    Thanks for the response. Under “System Preferences,” I set all my “Sound Effects” to play through the internal speakers, and Audio Input and Output set through the Kona.
    Still have the problem.
  • Jeremy Garchow
    August 6, 2009 at 9:29 pm
    [David de Vos] ” and Audio Input and Output set through the Kona. “
    Don’t set those to Kona. Set the output to Headphones or Line Out, and the input to internal mic.
    Jeremy
  • David De vos
    August 6, 2009 at 9:54 pm
    Okay. Did that. Still no change. Darn gremlins…
  • Bob Zelin
    August 6, 2009 at 10:20 pm
    AJA Control Panel
    Control Tab
    1) make sure you are not on “input passthru”
    2) are you on FREE RUN, or EXT REF. You better not be on VIDEO IN.
    3) if you are on EXT REF, what is your black gen ?
    Bob Zelin
  • David De vos
    August 6, 2009 at 10:39 pm
    Output: Test Pattern
    Genlock: Freerun
  • Jeremy Garchow
    August 6, 2009 at 10:45 pm
    And if that doesn’t work, try an uninstall and reinstall of the drivers.
