Activity › Forums › AJA Video Systems › Kona LHi residual audio static
David De vos
August 7, 2009 at 12:58 amUnfortunately, even with the right Kona card settings, I’m still having the problem.
Jesse Coane
September 22, 2009 at 1:14 pmI’ve been having this issue on and off since we get our Kona LHI cards. Lately it’s been very annoying. I’ve tried everything listed here. Did anyone have any luck on sorting this out?
thanks in advance
jesse
Jesse Coane
Director / Editor
The Concept Farm -
David De vos
September 22, 2009 at 4:27 pmHi Jesse,
The only fix I found – and yes, it DID fix the problem even though it’s a pain to do – is to reinstall OS 10.5.8 after you’ve physically installed the Kona Lhi. THEN download and install the latest NDD (make sure it’s NDD, otherwise your monitors will be screwed up) driver.
It took me a while to do, but it worked. The static issue has not returned. Let me know if it works for you.
Best,
Dave
Jesse Coane
September 22, 2009 at 6:02 pmthanks man. did you do a clean install? would an archive and install be sufficient?
thanks again
jesse
Jesse Coane
Director / Editor
The Concept Farm -
David De vos
September 22, 2009 at 6:13 pmI had just upgraded to my Mac Pro, so I did a full clean install. You could try either, I suppose. If it works, great. If not, try the other way. Let me know if it works! Don’t forget to repair disk permissions when you’re done.
