Activity › Forums › AJA Video Systems › KONA LHI Output screen goes crazy on playback then FCP crashes
  • Jeremy Garchow
    March 11, 2010 at 12:13 am
    Did you reinstall the NDD version of the driver? you didn’t specify.
  • Drew Kilcoin
    March 11, 2010 at 12:16 am
    by ndd what do you mean??? most up to date from the website?? if in that case yes…. thanks again for the responding
    Drew
    https://www.imdb.com/name/nm2398405/
  • Jeremy Garchow
    March 11, 2010 at 12:19 am
    [Drew Kilcoin] “ost up to date from the website?? i”
    No there’s two versions of the driver, the regular and NDD. NDD fixes issues like this, but you won’t be able to use the mac desktop out of your Kona card.
    Look at this page, and look at the link down from the top:
    https://www.aja.com/support/kona/kona-lhi.php
    It’s marked v7.5 NDD.
    Here’s the link for your convenience:
    https://www.aja.com/ajashare/AJA_KonaLHi_NDD_7.5.zip
    Make sure to install v7.5 first using the AJA uninstaller, then reinstall the newly downloaded 7.5 NDD.
    Jeremy
  • Drew Kilcoin
    March 11, 2010 at 12:21 am
    thanks will do this and see if it helps…..
    Drew
  • Drew Kilcoin
    March 17, 2010 at 9:44 pm
    A fix I got for this is when the problem starts to happen, hit Apple+F12 to take the PLayback screen away for a couple seconds and then re-hit Apple+F12 to put monitor back up and the problem goes away.
    Drew
  • Jerome Manato
    March 26, 2010 at 7:31 am
    If you’re using a breakout box, try connecting your Kona card output directly to your monitor bypassing the BOB. Maybe the BOB has the problem and not the card…Just a thought!!!
  • Drew Kilcoin
    March 30, 2010 at 10:43 pm
    no breakout box… again just have been turning all frames on and off with appleF12 and it stops the craziness and it doesn’t crash
    Drew
  • Drew Kilcoin
    April 1, 2010 at 9:01 pm
    well after changing the driver to NDD and moving around the slots to recommend slot has not stopped it from flickering. Yes I found a work around, but when it started to happen frequently, its annoying. So will be calling aja again and will get the same wow, we’ve never heard of that response.
    Drew
  • Drew Kilcoin
    April 1, 2010 at 9:15 pm
    Shipping me a new one… i just hope its the card
    Drew
  • Drew Kilcoin
    April 5, 2010 at 11:54 pm
    Well its not the card…. cause the new card which was sent by AJA is doing the same thing the old one did. SO I am going to put my setups up here and see if anyone has any possible solutions….
    Drew
Page 2 of 3
