Activity › Forums › Creative Community Conversations › Kona LHi and FCPX
Kona LHi and FCPX
Posted by Elliot Pollaro on January 8, 2013 at 11:05 pmI downloaded the latest Beta driver (February of 2012) which is a long time in my opinion. The video output im getting out of my 1080 timeline is terrible. The video aspect ratio is squeezed, the quality is very low.. I cant use this for detailed color correction. Has anyone found a FCPX solution for viewing from the Kona card to a professional color grading monitor?
Elliot
Jeremy Garchow replied 13 years, 8 months ago 2 Members · 14 Replies -
Jeremy Garchow
January 9, 2013 at 12:37 amThe regular drivers now work.
https://www.aja.com/en/support/kona/mac/kona-lhi/
Make sure your playback pref is set to “best quality”.
You also have to set the resolution/frame rate in the control panel before launching fcpx.
Elliot Pollaro
January 9, 2013 at 8:24 pmOk so the update works great and all, but now my HDMI monitor isn’t showing any color bars or video period. My HD SDI monitor is working great. Before I installed the update, both monitors were outputting video. I am wanting it to work on both monitors, any suggestions?
Jeremy Garchow
January 9, 2013 at 8:29 pmThe HDMI worked before the update?
Did you uninstall first?
Elliot Pollaro
January 9, 2013 at 9:00 pmI just uninstalled using the AJA Uninstaller. I then reinstalled the drivers, and the hdmi still doesnt work. It worked before I updated to the new driver.
Elliot Pollaro
January 9, 2013 at 9:02 pmIts not even working in general… I should see color bars on it.
Jeremy Garchow
January 9, 2013 at 10:54 pm[Elliot Pollaro] “Its not even working in general… I should see color bars on it.”
I’m sorry, what’s not working in general? Just the HDMI port or the AJA card?
What format is the frame buffer set to?
