Activity › Forums › Creative Community Conversations › Kona LHi and FCPX
Elliot Pollaro
January 9, 2013 at 11:42 pmHdmi Output:
Select: Primary 1080p29.97
Audio CH: 2 ChannelsProtocol: HDMI
Color Space: Auto Detect
RGB Range: SMPTE -
Jeremy Garchow
January 9, 2013 at 11:49 pmFlip RGB Range to RGB and see what happens.
Also try 1080sf29.97
Elliot Pollaro
January 10, 2013 at 12:23 amI tried that. I went and looked at my other computer running the same setup, and I copied all of the settings inside the Control Panel to make it identical, but my card still isnt showing HDMI output. I even switched cables to check if it was a cable issue.
Jeremy Garchow
January 10, 2013 at 12:39 amTime to call AJA unless it has something to do with your monitor (like the wrong input is selected, etc).
