Activity Forums Adobe After Effects Keyframe Problem
  • Keyframe Problem
    Posted by Christopher Mallan on May 29, 2011 at 5:36 pm
    i am doing some really basic animation which involves moving an object from one side of the screen to the other, pausing for a second, then moving again. I havent always had this problem but when i want it to pause, i set a key frame one frame before the point where i want the object to move again and set it as the same values as when the image first paused, leaving it at the same point for x amount of frames. for some reason in the time that the image is paused the values alter as if they have a mind of their own and then return to the original value. is there a setting or something i should be aware of?
    many thanks
    Chris
    Roland R. kahlenberg replied 15 years, 3 months ago 4 Members · 4 Replies
  • Kevin Camp
    May 29, 2011 at 6:19 pm
    The issue is referred to as the boomerang effect. Aharon rabinowitz has a tutorial covering it, if you want to search the cow’s tutorials…
    To fix it, try selecting the keyframes, then choose animation>keyframe interpolation and set the spacial interpolation to linear.
    Kevin Camp
    Senior Designer
    KCPQ, KMYQ & KRCW
  • Todd Kopriva
    May 29, 2011 at 6:48 pm
    There’s more information here, including a link to the video from Aharon that Kevin mentioned.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Christopher Mallan
    May 30, 2011 at 9:02 am
    Great. Thought it would be something simple. Thanks for the swift reply!
    Chris
  • Roland R. kahlenberg
    May 30, 2011 at 10:17 am
    All good solutions there BUT, the way you’re going about creating a pause is not the right way. The proper way to create pauses is to use the Hold keyframe. Check the links that Todd provided.
    Cheers
    RoRK
    AE Training in South East Asia. AE templates for sale and rental. Click here for more
