Activity Forums Apple Final Cut Pro Legacy Issue with Easy Setup for AVCCAM AG AC160
  • Issue with Easy Setup for AVCCAM AG AC160
    Posted by Nick Dyer on January 12, 2012 at 3:43 pm
    Hi guys,
    I recently purchased the new Pansonic AG AC160 and am I am trying to figure out the best set up in Final Cut Pro 6 for the footage that I am shooting.
    I am currently shooting in PH 1080 30P. My setup right now is:
    I am running into an error message however when I try to render the footage…I get an error message stating “Codec not found. You may be using a compression type without the corresponding hardware card.”
    What I am trying to figure out is if my set up is right and if not, what should I change?
    Also, how should I compress/export to get the best quality?
    Thank you for you help I truly appreciate it.
    -Nick
    Brown Lisa replied 13 years, 10 months ago 4 Members · 5 Replies
  • Rafael Amador
    January 12, 2012 at 4:07 pm
    Hi Nick,
    That’s a video camera, so normally should shot 29,98.
    If you don’t have it, download the PANASONIC AVCCAMImporter component to edit native, or Log&Transfer to convert to Prores.
    rafael
    http://www.nagavideo.com
  • Nick Dyer
    January 12, 2012 at 4:12 pm
    Is AVCCAM Importer available for Final Cut Studio 2 (FCP6?)
    And do you mean I should shoot in 29.98? (Isn’t that what 30 is?) I want to know how to set up the footage in FCP and how I should export it…
  • Steve Eisen
    January 12, 2012 at 11:28 pm
    By using Log and transfer, there is no need to use Easy Setup. Drop transcoded clip in timeline and let FCP figure it out. Select yes when asked.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Rafael Amador
    January 13, 2012 at 2:19 am
    [Nick Dyer] “Is AVCCAM Importer available for Final Cut Studio 2 (FCP6?)”
    I’m afraid not.
    This is the PANA URL:
    https://eww.pass.panasonic.co.jp/pro-av/support/desk/e/download.htm#avccamip
    [Steve Eisen] “By using Log and transfer, there is no need to use Easy Setup. Drop transcoded clip in timeline and let FCP figure it out. Select yes when asked”
    Right.
    L&T will find out the real time-base of the footage and FC will conform the sequence.
    When you have your prores files, have a look to the Browser info.
    You will see 29,98fps.
    When video cameras are saying 30p, they really means 29,98p. that’s the standard for video.
    Different is when dealing with some DSLRs camera (canon) that are shooting real p30.
    rafael
  • Brown Lisa
    November 26, 2012 at 7:07 am
    FCP6 is too old. 1080 30P AVCHD is not a good editing format for FCP 6. I advice you to upgrade to FCP 7 or FCPX.
