Activity Forums Apple Final Cut Pro Legacy Is there a trick to avoid the “abortion on drop frame” capturing from VHS ?
  • Is there a trick to avoid the “abortion on drop frame” capturing from VHS ?
    Posted by Fredy Schwerdtner on November 20, 2009 at 2:20 pm
    I was wondering if anyone knows a trick to avoid the “abort on drop frame” function when there is a need to capture video from a VHS tape. I know if I deselect the function on preferences, I will get a non synced material … but it is painfull ( I lost 1 and 1/2 hour last night ) when you loose hours of captured material if FCP finds a single drop frame just when you are about to finish the capture …..
    Thanks to you all in advance.
    MacBook Pro 17″
    2.5 GHz Intel Core 2 Duo
    4GB 667 MHz DDR2 SDRAM
    (2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
    OS X 10.5.7
    Final Cut Studio 2
    Fredy Schwerdtner replied 16 years, 7 months ago 6 Members · 11 Replies
  • 11 Replies
  • Tom Wolsky
    November 20, 2009 at 3:22 pm
    Get rid of those USB drives. Apple doesn’t support them for video applications.
    What’s doing the converting? Are there video breaks in the VHS tape?
    All the best,
    Tom
    Class on Demand DVDs “Complete Training for FCP7,” “Basic Training for FCS” and “Final Cut Express Made Easy”
  • Fredy Schwerdtner
    November 20, 2009 at 5:49 pm
    I’m using Canopus ADVC-300 with my MacBook Pro and a 800 firewire External LaCie
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • Tom Wolsky
    November 20, 2009 at 6:18 pm
    Did you disconnect the USB drives? Are there video breaks in the VHS?
    All the best,
    Tom
  • Fredy Schwerdtner
    November 20, 2009 at 9:11 pm
    On USB ports are Keyboard and mouse. It is an old VHS tape (media from the last century) to became a DVD of memories.
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • Mark Suszko
    November 20, 2009 at 11:10 pm
    There *is* I seem to recall, a check box somewhere in preferences I think that selects if it should abort or continue thru a time code break. But I don’t have the app in front of me as I write this, sorry.
  • Thaxter Clavemarlton
    November 21, 2009 at 12:56 pm
    Dub the VHS to a DV tape, then capture the DV tape.
  • John Fishback
    November 21, 2009 at 11:39 pm
    Using the ADC with a FW drive may cause problems. We use an ADC to play video with Pro Tools and if another FW device is connected at the same time as the ADC, the Mac becomes very unhappy.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)
    Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
  • Fredy Schwerdtner
    November 22, 2009 at 12:05 am
    Do you think that using my system HD (as a scratch disk) instead of the external one would help ?
    MacBook Pro 17″
    OS X 10.5.7
    Final Cut Studio 2
  • John Fishback
    November 22, 2009 at 6:30 pm
    That’s not advised. Your OS is constantly “checking” with your system disk and those “interruptions” mess with video (dropped frames, etc.) that must be played out (or captured) in realtime.
    John
  • Sean Murphy
    January 14, 2010 at 3:19 pm
    Freddy I have come up against the same problem, I was wondering if you managed to find a solution?
    Cheers
    Sean
