Activity › Forums › Apple Final Cut Pro Legacy › Is there a trick to avoid the “abortion on drop frame” capturing from VHS ?
Fredy Schwerdtner replied 16 years, 7 months ago 6 Members · 11 Replies
Fredy Schwerdtner
January 14, 2010 at 6:17 pmSean,
as I have read here and over the internet, if you uncheck that option on FCP preferences you will come up with unsync material. Unfortunatly I have not found a solution for that. Sometimes I just need the hole material on a VHS tape to be edited after the capture and throw away the dropped frames ….
If you find a way, please let me know.
greetings.MacBook Pro 17″
2.5 GHz Intel Core 2 Duo
4GB 667 MHz DDR2 SDRAM
(2) External HD LaCieMac (400/800 FW and USB)with 500GB -(2) USB External HD Western Digital (in cases) with 750GB
OS X 10.5.7
Final Cut Studio 2
