Activity › Forums › Apple Final Cut Pro Legacy › Is it still compressed when taken out of the BNC?
Posted by Arnljot Bringedal on February 12, 2007 at 6:30 pmHey!
I use a sony Z1 and a canon xm2 ( GL2 in the US? )
I am out in the field as I am typing this…
I have NEVER done a greenscreen shot – and I have heard that DV – is less than ideal ( or maybe hopeless) to pull a key from….
My question: If i capture analoge from the BNC – or the “yellow ” line out – output…. Is it still DV? Can I cheat this way to get a good key?
The editor called me and wants me to do a greenscreen shot where I am, told him that I only brought DV – and that it probably wont work…..
*** Norwegian videojournalist & Editor***
Uli Plank replied 19 years, 6 months ago 7 Members · 14 Replies -
Chris Tompkins
February 12, 2007 at 6:38 pmWell, U could hook up the Analog compsite out to a Digi-Beta deck but still, look @ the camera u r capturing from: It is still 4.1.1 color space and that is where the problems with keying are. U could hook up the Analog compsite out to a capture card and capture live -10bit uncompressed – but again, same deal with the 1/3 CCD camera. Some people can pull an adequate key from DV footage. It’s subjective though.
Kevin
February 12, 2007 at 6:40 pmYes, it’s still compressed. It’s compressed from the moment the DV Camera records the image. Don’t use composite out (the yellow rca/bnc) that won’t help.
Light the green screen as evenly as possible and you might be ok.K
Arnljot Bringedal
February 12, 2007 at 6:44 pmThe guy in the adjacent hotelroom has an HVX-200 – and I can borrow it.
Will that give a better key? And what “mode” should I shoot in to get the best key?
( will have to downconwert to SD – before I send it back home )*** Norwegian videojournalist & Editor***
Chris Tompkins
February 12, 2007 at 7:07 pmYou’ll get better results with that camera. Shoot in the Hi-Def mode. 1080p
I think shooting in progressive mode will yield better keying results also. -
Jeff Carpenter
February 12, 2007 at 7:43 pmDo you have any kind of external deck? That’s the real question. If you can get ahold of a Beta or Digibeta deck then yes, you can do as you suggest. But I wouldn’t use composite out. The S-Video out will be ok, though. Most of those cameras don’t compress to 4:1:1 until after it passes those ports. You CAN record a non-compressed video signal out of them as long as you have something to record on.
Uli Plank
February 12, 2007 at 7:49 pmIf you are aiming for SD in the end: Yes, it will help a lot!
The HVX200 can record in 4:2:2 (better color resolution) plus it’s HD, so every little artefact on the edges of the key will be scaled down (hopefully into oblivion) when converting the final composite to SD.
Regards,
Uli
Author of “DVDs gestalten und produzieren”, a book on professional DVD-authoring in German.
Arnljot Bringedal
February 12, 2007 at 8:26 pmBut should I do the keying while its HD and then downconvert?
Or: Downconvert and then do the key?
Becker
Thanks for helping folks! Nice crowd here at the cow.
Arnljot Bringedal
February 12, 2007 at 8:29 pmWould any kind of capture card – AJA – do the trick?
Walter Biscardi
February 12, 2007 at 9:00 pm[Becker] “Would any kind of capture card – AJA – do the trick?”
The head of the HVX-200 is uncompressed. If you were to feed directly out of that camera to an AJA card you could capture 8 or 10bit uncompressed video which would lead to a very nice key.
Walter Biscardi, Jr.
HD Editorial & Animation for Food Network’s “Good Eats”
HD Editorial for “Assignment Earth”“I reject your reality and substitute my own!” – Adam Savage, Mythbusters
Walter Biscardi
February 12, 2007 at 9:01 pm[walter biscardi] “The head of the HVX-200 is uncompressed. If you were to feed directly out of that camera to an AJA card you could capture 8 or 10bit uncompressed video which would lead to a very nice key.”
Should clarify that, it’s uncompressed BEFORE you record to tape. If you record the signal to tape, and then play that out of the camera to your system, you’re just outputting DV. But simply record the signal directly from the camera to your system live, and it will be uncompresed.
