Activity Forums Apple Final Cut Pro Legacy is it possible to copy a 14gig FCP clip?
  • is it possible to copy a 14gig FCP clip?
    Posted by E. Eric johnson iii on September 14, 2006 at 8:49 pm
    hello brilliant cow brains-
    i have a huge (14gig) clip that was captured live from an HVX-200 into FCP via FW. the clip exists and works in FCP; however, i cannot completely copy the file.
    the computer starts to copy to another drive (or even desktop) then it locks up. i’ve tried cutting the clip into smaller chunks, but it won’t allow that either. it just locks-up, no ‘spinning beachball of death’ or anything. since this is the only clip of the media i have, i’ll feel a little nervous ’til i have backed it up.
    what am i missing or forgetting in this seemingly simple process?
    thank you for your help,
    e3
    e. eric johnson iii
    eric@lillmonster.net
    lill monster founder/producer-director
    water channel: producer/virtual set operator
    HomeandGardenCreative.com: producer/editor
    now in principal photography – START 2 FINISH: What It Really Takes to Race A Bike
    E. Eric johnson iii replied 19 years, 11 months ago 8 Members · 17 Replies
  • 17 Replies
  • Aaron Neitz
    September 14, 2006 at 9:17 pm
    Sounds like some corruption…. 14gig is not that big (we shuffle around stuff like that all the time in HD).
    So you’ve tried from in FCP to do an In/Out and export “self-Contained.” ??? Or are you copying from the Finder? Does it always seem to lock up in the same place?
  • E. Eric johnson iii
    September 14, 2006 at 9:29 pm
    hi charlie-
    thanks for the quick post… i’ve moved bigger files myself. i thought it was a corrupt file as well, but it plays fine in FCP. tho’ it does seem to lock-up about the same place. i’m gonna give it one more try… i repaired my permissions just for the heck of it. cross your fingers and i’ll post if there’s any progress or not.
    thank you again,
    e3
    e. eric johnson iii
  • Jeremy Garchow
    September 14, 2006 at 10:00 pm
    Sorry to mention the obvious and I’m sure you’ve checked this, but make sure you have that much room on your target disk
    September 14, 2006 at 10:30 pm
    no problem mentioning the space issue… unfortunately it’s not that. here’s the thing that’s bugging me now:
    it will copy the file but only to the same drive? however, now it doesn’t stop copying at the same spot, it’s random. it actually got to 11 of the 14 gigs copied over prior to the latest lock-up.
    the FCP export is doing the same thing… any other ideas? is there a setting i don’t know about? it just seems to hate this certain file.
    arrrgh.
    e. eric johnson iii
  • Jim Martin
    September 14, 2006 at 10:53 pm
    So you can copy fully to the same drive, but not a different drive?
    are you copying to an external? bad cable perhaps?
    Just tossing out ideas
    Jim
  • Tom Matthies
    September 14, 2006 at 11:02 pm
    A PC formatted drive perhaps? Is it formatted for Mac OS?
    Tom
  • Jeremy Garchow
    September 14, 2006 at 11:08 pm
    Get info on the clip, twirl down the ownership and permissions pane and make sure you are the owner aand it’s all set to read and write.
    oh, yeah… the file copied fully within the same drive, but still won’t make it to another external drive or even the desktop.
    as far as a mac or pc formatted drive, i tried using both… to the same effect. it starts out all happy and copying, but then it locks-up. it’s like the file is laughing at me!
    e3
    e. eric johnson iii
    September 14, 2006 at 11:24 pm
    hi jeremy,
    no luck… i tried it twice. it’s wide open in the info. right now it’s the safest file in the world. it just doesn’t want to complete a copy to another drive.
    arrgh.
    e3
    e. eric johnson iii
  • Jeremy Garchow
    September 15, 2006 at 12:05 am
    [WaterBoy] “the file copied fully within the same drive”
    Duplicate the file and then copy the duplicate.
    Jeremy
