Activity › Forums › Apple Final Cut Pro Legacy › is it possible to copy a 14gig FCP clip?
E. Eric johnson iii replied 19 years, 12 months ago 8 Members · 17 Replies
Bret Williams
September 15, 2006 at 2:16 amPut the file in a folder and copy that. Stufit and copy that. Just try some stuff.
E. Eric johnson iii
September 15, 2006 at 5:51 pmthank you to all for the suggestions… i’ve been trying them all and a few others. still no go.
i shall continue various combinations and hope for the best. if i figure it out, i’ll post it. sheesh.
e. eric johnson iii
eric@lillmonster.net
lill monster founder/producer-director
water channel: producer/virtual set operator
HomeandGardenCreative.com: producer/editornow in principal photography – START 2 FINISH: What It Really Takes to Race A Bike
Jeremy Garchow
September 15, 2006 at 6:16 pmhave you tried other drives? If the clips copies to whatever drive it’s on, then it seems to me to be some sort of permissions error on whatever you are copying to.
Jeremy
E. Eric johnson iii
September 16, 2006 at 4:09 amthanks jeremy — i tried that too, other files copy no problem. it appears to be this one clip. maybe there’s some corruption somewhere, but then why would it play OK in FCP?
i’m going to readdress after this weekend.
thank you for the input.
e3
e. eric johnson iii
Rafael Amador
September 16, 2006 at 9:27 amHi WaterBoy,
Open your file with QT. Open a new window. Copy and paste your file in the new window, and try to save it as autocontained in the other disk. May work.
Yours is very curios problem. Thats normally happens when disks are full or too fragmented. If the file would be corrupted I think you couldn’t make any coppy. And if in the end is corrupted, try FileJuicer. Works grate.
Salud,
rafael -
E. Eric johnson iii
September 18, 2006 at 5:24 pmthat’s a good idea… but it still crashes? i tried it twice. i’m baffled. i have one idea left, i’m gonna try it, but i’m a little embarrassed as to say what it is. if it works, i’ll post back.
thank you rafael and everyone else.
e3 of the wacky un-copy-able file
e. eric johnson iii
