Activity Forums Avid Media Composer Is DV25 411 equal to 1-1?
  • Is DV25 411 equal to 1-1?
    Posted by Chaz Shukat on July 5, 2007 at 11:44 pm
    I’ve taken over a project on an Xpress Pro that has been digitized at DV25 411. They tell me that’s how it’s going to be broadcast on cable network, no up-rezzing! Say’s they’ve done this before. Is this kosher? Is it an “online” resolution?
    Also, how do you bring up the scopes on the Xpress Pro? They tell me they exist but I can’t seem to find them.
    C=-
    Chaz Shukat
    Author of “EDITING REALITY”
    http://www.chazmoedit.com
    John Pale replied 19 years, 2 months ago 8 Members · 17 Replies
  • 17 Replies
  • Joe Womble
    July 6, 2007 at 12:01 am
    You can bring up your scopes by clicking on “Tools/Video Input.”
    You can also see either a waveform or vectorscope as one of the windows in your color correction toolset.
    Regards,
    Joe Womble
  • Chaz Shukat
    July 6, 2007 at 2:05 am
    Joe, the first thing I checked was the tools. There is no video input under tools. This is an Xpress Pro, not a MC. As for the color correction, I’ve looked all over that interface, don’t see how to bring up scopes.
    Chaz Shukat
  • Grinner Hester
    July 6, 2007 at 2:36 am
    you really need external scopes but as Joe mentioned you can use the scopes in the video input tool while capturing.
    DV25 is 5:1 compression in a 4:1:1 color space. It is not an online quality but it is aired everyday. “broadcast quality” is a relative term as 4th generation vhs is broadcasted. Doesn’t make it pretty… just makes it a matter of opinion as to what is aired. To me it depnds on only the sunbject matter but each network has their own set of rules.
  • Rhewitt
    July 6, 2007 at 4:37 am
    External scopes are always the preferred choice.
    From memory the Tools/Video option only appears if you are connected to a Mojo. Sort of makes sense – without a Mojo you’re only outputting to DV unless you have an AJA/Black Magic card etc.
  • Chaz Shukat
    July 6, 2007 at 1:03 pm
    I don’t have a Mojo. If there is a way, please be very specific as to what and where and how because I still don’t see any way to bring up scopes, Video Tool menu or, color correction mode or otherwise.
    Thanks for the enlightenment on the DV25 411. I didn’t think it was equivalent of 1-1 as I was being told.
    Chaz
  • John Pale
    July 6, 2007 at 2:13 pm
    [Chaz Shukat] “Thanks for the enlightenment on the DV25 411. I didn’t think it was equivalent of 1-1 as I was being told.”
    In a sense, it IS 1:1. DV is compressed 5:1 IN THE CAMERA/DECK. The Avid is not adding any compression when you capture it. Recapturing 1:1 will not make it any better, if it was DV to start with. It cannot be “uprezzed”…it is what it is. Just set your renders to 1:1 in the Media Creation settings and your effects and graphics will improve by not recompressing as DV.
  • Chaz Shukat
    July 6, 2007 at 3:02 pm
    Great post John, that clears up a lot for me. 1-1 means no compression, even if its DV quality, which I’m not used to thinking of as “online” quality.
    BTW, is DV25 411 different than just plain old DV25?
  • David Braswell
    July 6, 2007 at 5:35 pm
    DV25 411 = DV25, yes, they are the same.
    Toolset–> Color Correction to bring up your scopes.
  • Chaz Shukat
    July 6, 2007 at 8:01 pm
    OK, I guess I’m not being clear enough about the scopes. I don’t mean the color correction scopes, I mean regular video scopes (that let you check and see if you are within broadcast limits) and vector scopes. :-}
  • David Braswell
    July 7, 2007 at 3:54 am
    That’s what I mean too :-> Chaz, in the hidden triangle dropdown of the color scopes(histogram and parade), you can choose Y, YC, and a vectorscope. Additionally, depending on your version of Xpress, there is a broadcast legalizer plugin. Check for all this in the help file. Of course, there is no substitute for a good hardware scope. But, this is better than nothing.
