Activity › Forums › Adobe Premiere Pro › Is AVI 64 bit on Win 7 ?
Posted by Tom Daigon on July 26, 2012 at 6:11 pmPC cutters question.
I know that Quick Time is 32 bit.And using it can effectively slow down exports from CS6.
Is AVI 64 bit on Win 7? If so it should be faster export from CS6, no?
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
https://www.youtube.com/watch?v=XRIg6h-LIm0
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raidAnn Bens replied 14 years, 2 months ago 5 Members · 13 Replies -
Vince Becquiot
July 26, 2012 at 6:18 pmIt is my understanding that AVI was last updated in 1947…
Cutting on both PCs and MAC, I have seen very little difference. Even on a PC I export Animation since the majority of cutters want QT files, the size is also significantly smaller.
Vince Becquiot
Indigo Live
San Francisco – Bay Area -
Tom Daigon
July 26, 2012 at 7:44 pmHa ha. If that is the case I would stick with QT DNxHD since for mastering since it is the defacto standard on the PC (since Prores is not readily available for mastering).
Tom Daigon
HP Z820 Dual 2687
64GB ram
Dulce DQg2 16TB raid -
John-michael Seng-wheeler
July 26, 2012 at 10:08 pm[Tom Daigon] “I know that Quick Time is 32 bit.And using it can effectively slow down exports from CS6.
Is AVI 64 bit on Win 7? If so it should be faster export from CS6, no?”
The problem is that Quicktime files must be encoded in premiere using Quicktime the program, which is 32bit.
AVI files, on the other hand, are encoded by Premiere/AME directly.
The 32/64 bit question doesn’t affect the files themselves, just the programs encoding them.
That said, Vince is right… AVI is terribly old and doesn’t really support any useful modern codecs, so I don’t quite know why you’d use it anyway.
I master to DNxHD or Avid 1×1.
Walter Soyka
July 27, 2012 at 1:57 pm[John-Michael Seng-Wheeler] “That said, Vince is right… AVI is terribly old and doesn’t really support any useful modern codecs, so I don’t quite know why you’d use it anyway.”
AVI wraps CineForm.
I’m currently using a hybrid approach to intermediates; for movies, I write CineForm AVIs on the PC and write ProRes QuickTimes on the Mac. These intermediates are easily read on either platform. (I also do a lot of work with image sequences, and so I’m sometimes able to avoid this problem altogether.)
I had hoped to have time this week to do some rigorous testing of Grass Valley’s new cross-platform HQX codec, but work got in the way. I will hopefully have some results to share next week.
Walter Soyka
Creative Cow Forum Host: Live & Stage Events -
Tom Daigon
July 27, 2012 at 4:40 pmWalter, I look forward to hearing about your HQX experience.
Tom Daigon
HP Z820 Dual 2687
64GB ram
Tom Daigon
July 27, 2012 at 5:45 pmWalter, I installed the GV codec (HQX) on my PC today. A rocky start at best. After installing I rebooted and looked for codec in PrP. AE and AME. It was nowhere to be found. I did a very detailed search under every possible option, so unless Im as blind as a bat, something is not kosher here.
Tom Daigon
HP Z820 Dual 2687
64GB ram
Walter Soyka
July 27, 2012 at 5:57 pm[Tom Daigon] “Walter, I installed the GV codec (HQX) on my PC today. A rocky start at best. After installing I rebooted and looked for codec in PrP. AE and AME.”
I can’t seem to use it as a custom sequence codec in Premiere, but I can export to it from Ae, Pr, and AME if I select AVI as the format, then select Canopus HQX as the codec:
Walter Soyka
Tom Daigon
July 27, 2012 at 6:08 pmAh yes, I was looking for Edius or GV but not Canopus. Not having access to it in Premiere is surprising.
And is having to have AVI as the wrapper a limitation in any way?
Tom Daigon
HP Z820 Dual 2687
64GB ram
Ann Bens
July 27, 2012 at 6:25 pmIn Premiere its under AVI.
Drop down the Video Codec, there you will find it.———————————————–
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Tom Daigon
July 27, 2012 at 6:26 pmThank you Ann!
Tom Daigon
HP Z820 Dual 2687
64GB ram
