Activity › Forums › Apple Final Cut Pro › Is anyone rendering 23.976 footage transcoded or rewrapped with FCPX out of Color? Xto7 7toX
David Camacho replied 13 years, 6 months ago 5 Members · 41 Replies
Oliver Peters
March 21, 2013 at 10:49 pm[Shane Ross] “The biggest kick I get out of this conversation is how much you all still rely on FCS to do stuff. You don’t just use FCX.”
I think you need to view it differently. FCP X at the moment is an editing platform that other things can work with. It’s not an all-in-one application and in this go-around, I don’t believe Apple intends to do that any longer. FCP X is a good cutting environment for those who adapt to its style, but for advanced workflows you’ve got to go outside of it. That can be Resolve or Smoke or other apps – or it can be what you already own – FCS.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Shane Ross
March 21, 2013 at 10:52 pm[Oliver Peters] ” FCP X is a good cutting environment for those who adapt to its style,”
I know…like Bill Davis. It’s you two, that work like I work, have needs like my needs…that can’t seem to stick to only FCX.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Oliver Peters
March 21, 2013 at 10:58 pm[Shane Ross] “It’s you two, that work like I work, have needs like my needs…that can’t seem to stick to only FCX.”
Well, for me, there are parts of X I like and parts I still hate. Since I freelance, I currently am asked to use most of the various NLEs. When it comes to sending stuff out-of-house for mixes or grading, there are a number of ways to make it work if you cut in X. Often the easiest is to get it to/from FCP 7 and then go from there. The last couple of jobs I’ve cut were conformed/”onlined” in FCP 7 😉
– Oliver
Orlando, FL
David Camacho
March 21, 2013 at 10:59 pmI just finished a project FCP7 to color, 23.98 prores HQ recorder on a Samurai and all of my render files round tripped from color came back 24fps…
Opened new project in color and just imported single clip from
Samurai recorded files and color sees it as 24fps, Quicktime sees it as 23.98.Exported same clip from FCP same as source a Color sees it as 23.98.
What is going on ????
Shane Ross
March 21, 2013 at 11:31 pm[David Camacho] “What is going on ????”
Color hates samurai. It likes ninjas.
Shane
Little Frog Post
Oliver Peters
March 22, 2013 at 12:42 amI just ran some tests. I think it’s your day for voodoo, Jeremy. I imported 3 files directly into Color (Alexa, BMCC ProResHQ, F3 recorded on KiPro). All 1080p/23.98. I rendered in Color, imported rendered clips into FCP 7 and then exported to X via XML (7toX). In all cases (plus QT 7) the files and sequences were ID’ed as 23.98fps. Go figure.
– Oliver
Orlando, FL
Jeremy Garchow
March 22, 2013 at 12:49 am[Shane Ross] ” It’s you two, that work like I work, have needs like my needs…that can’t seem to stick to only FCX.”
Did you stick with only fcp7?
I didn’t.
With X, X2Pro worked great for me to get AAFs to ProTools.
If I had a Blackmagic card, the round trip to resolve would have been fairly painless.
Even needing to go to an XML based system (FCS 3 or Pr) is OK for timeline work.
Avid? I haven’t tried getting to it, but I imagine some combo of Xto7toX and Automatic Duck.
If a person likes fcpx (which I like a lot of it) the interchange really isn’t 100% terrible or impossible.
I find interchange in cs6 to be more difficult (not including dynamic link to Ae).
Jeremy
Jeremy Garchow
March 22, 2013 at 12:52 amAs I said, all clips NOT transcoded with X worked fine.
Arri Alexa, log and transferred clips from fcp7, etc.
It was clips that were transcoded or wrapped in X that are the problem.
Try something like P2, AVCHD, or XDCam/C300 media.
I can try and send you some tomorrow if you don’t have any on hand.
If it is voodoo on my system, at least I can chase it.
Oliver Peters
March 22, 2013 at 1:09 am[Jeremy Garchow] “As I said, all clips NOT transcoded with X worked fine. “
OK, so we are back to what I said in the first place. It’s an FCP X bug, not a Color problem. Or it’s in Xto7. The issue is likely a mis-tagging of frame rate metadata. At various points Apple has frequently mislabeled 23.98 as 24 (but meaning 23.98). It could be there’s an error in the XML translation due to that. Also there are metadata differences between how Apple writes the tags for its 23.98 and how others write 23.976.
– Oliver
Orlando, FL
