Activity › Forums › Apple Final Cut Pro Legacy › insert clip to tape problem (Aja IoHD + DigiBeta)
Posted by Kresimir Rodich on October 17, 2008 at 8:21 amHello,
I have a problem with final cut pro2 when i try to insert part of clip to tape.
I’m outputting to Digi Beta over Aja IoHD so when output is done i have 1-3 black frames at the end of insert instead of clean cut to next shot.
i read some threads similar to my problem and guy sed to try clear all video effects from clip, I have two of them: color correction and de-interlace.
so I try to do that to and same thing.
Please if anyone had similar problem or know how to correct it HELP!!!!
Thanhs and regards Kreso.Kevin Monahan replied 17 years, 11 months ago 6 Members · 12 Replies -
Ben Holmes
October 17, 2008 at 11:58 amIs this a random 1-3 frames? if so you have a reference issue. If it’s always a certain number of frames out (in which case you will have the same number of frames missed at the start of the edit) you can adjust the edit offset in the device control preset.
It’s a common mistake to this that ANY layoff to tape, especially when you need to insert edit, does not require genlock. All decks need something to lock up to during preroll, and if you have no genlock between the deck and the computer, the deck will just find it’s own lockup point – where the control track is synchronised so the edit happens on the start of a frame.
There is a cheap way of achieving this now – the AJA Gen-10 I think – which every edit suite should have, or house genlock equivalent.
Coming from a tape background this was drummed into me a long time ago….
Ben
Edit Out Ltd
FCP Editor/Trainer/System Consultant
EVS/VT Supervisor for live broadcast
RED camera transfer/post
Independent Director/Producer -
Bouncing Account needs new email address
October 17, 2008 at 2:14 pm[Ben Holmes] “There is a cheap way of achieving this now – the AJA Gen-10 I think – which every edit suite should have, or house genlock equivalent.
“There’s an even cheaper way to do this, nearly instantly… and at no cost, in a pinch.
Turn on any camera that you have (lens cap can stay on) and connect its composite output to the deck’s sync input, and loop it to any other source that needs to be gen-locked.
The camera’s output will generate a signal that the system can lock to.
Ben Holmes
October 17, 2008 at 2:23 pmA Gen-10 is a lot cheaper than a camera – assuming you have one knocking around whenever you need one.
I can see where you are going technically, but I’m not sure that’s technical advice I could subscribe to – any old video camera’s composite output is not a stable sync source IMHO. It might be, in the same way as the camera with a lens cap on MIGHT be generating video black…
Why do people cheap out on Genlock, then complain about bad edits to tape? Not aimed specifically at you, Matte.
Ben
Edit Out Ltd
October 17, 2008 at 3:09 pm[Ben Holmes] “A Gen-10 is a lot cheaper than a camera – assuming you have one knocking around whenever you need one.
“I didn’t say to BUY a camera, I’m pointing out that if you need something to gen-lock to RIGHT NOW, any camera that you might have will do the job.
That even goes for a home video camcorder.Waiting the time it takes to order and receive a Gen-lock “black box” will not save an edit under a “need it this afternoon” deadline.
Kresimir Rodich
October 17, 2008 at 3:17 pmTnx Ben,
Eveything is genlocked (Tri-level sync), in 1st try I had 1f mised frame at the start of edit , adn at the end 1f was black.
2nd try only last frame mist and was black.
Then I updated firmvare for IOHD (sync issue fix) and nothing -
Arnie Schlissel
October 17, 2008 at 3:37 pm[Kresimir Rodich] “Eveything is genlocked (Tri-level sync),”
Digibeta should not have tri-level sync. Your generator should be set to NTSC or PAL for use with digibeta. Also, some decks cannot do inserts, some need to have the proper menu settings for inserts.
Arnie
Post production is not an afterthought!
https://www.arniepix.com/ -
Kresimir Rodich
October 17, 2008 at 3:38 pmSorry for double post.
We have house sync, Tri-Level Sync from Blackmagic.
Our all facility is HD. -
Kresimir Rodich
October 17, 2008 at 3:45 pmI know, I select the needed format manaly if is not automatic switched
