Activity › Forums › Apple Final Cut Pro Legacy › insert clip to tape problem (Aja IoHD + DigiBeta)
Kevin Monahan replied 17 years, 11 months ago 6 Members · 12 Replies
Jeremy Garchow
October 17, 2008 at 7:06 pmAnd your deck is set to external ref and the io Control panel says ref in and it’s not tri level, but bi level sync?
Jeremy
Kevin Monahan
October 17, 2008 at 8:37 pmAre you using RS-422 Device Control? Is there a Playback Offset? It should be set to 0. What is your drive set up and Io connectivity like?
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro
