Activity › Forums › Adobe After Effects › Indiana Jones map trouble
  • Greg Burrus
    February 14, 2012 at 5:41 am
    Not sure how you actually built yours in comparison to the tutorial but I did the tut real quick and the only way I was able to get sliding is if I put the effect on another layer in 3d space and offset the z position. Unless you have another effect that it is interfering with it it should work.
    It would be hard to tell what is wrong in you scene with out a screenshot or a project file. I have uploaded my file for comparison 3691_writeoneffectfolder.zip
    https://mogra.g2bproductions.com/ – Blog
    https://g2bproductions.com/ – Portfolio
  • Ryan Gibson
    February 14, 2012 at 5:46 am
    “Not sure how you actually built yours in comparison to the tutorial…”
    As I said in my post, I followed the tutorial exactly -_-
  • John Cuevas
    February 14, 2012 at 12:27 pm
    Without seeing exactly how you placed your keyframes, we are just guessing. If you collect your files and zip up the project – you can upload it here(last icon in the reply dialogue). I’d be happy to take a look and see if I can determine where the project got off track.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Ryan Gibson
    February 16, 2012 at 1:55 am
  • Darby Edelen
    February 18, 2012 at 2:30 am
    Disable the Continously Rasterize switch on the layer you have applied Write-On to.
    Darby Edelen
  • Ryan Gibson
    February 18, 2012 at 8:29 pm
    Can’t switch of Rastersize, otherwise the image would be pixelized.
  • Darby Edelen
    February 18, 2012 at 10:53 pm
    [Ryan Gibson] “Can’t switch of Rastersize, otherwise the image would be pixelized.”
    Well then you’re stuck. You can’t have both as you’ve set it up. It’s just the way continuous rasterization behaves.
    You could pre-compose the continuously rasterized vector image in a composition with the largest resolution you’ll need, then you can place that large composition in your composition without the need for the continuously rasterize switch.
    Darby Edelen
  • Ryan Gibson
    February 20, 2012 at 12:35 am
    Ah, I see.
    I’ll try it out and see if it fixes the problem.
    Thanks again, guys!
  • Ryan Gibson
    February 24, 2012 at 5:21 pm
    Thanks again! Got it all done!
    https://www.youtube.com/watch?v=ThMUVFthcmM
    I really appreciate your help, guys.
