Activity Forums Adobe InDesign Indesign files try to open in Premiere
  • Indesign files try to open in Premiere
    Posted by David Goodwin on March 19, 2015 at 11:51 am
    Every time I try to open regular inDesign CC 2014 files it tries to open in Premiere (which doesn’t work obviously). I tried changing the ‘open with’ and properties settings but it fails to keep the change. with the latter selecting the indesign.exe file and ok-ing it makes no difference, it fails to show in the options. I can open files with inDesign or drag and drop into the program but is there a solution to this?
    Lebanon Raingam replied 11 years, 4 months ago 2 Members · 1 Reply
  • Lebanon Raingam
    March 25, 2015 at 6:48 am
    Hi David,
    Have you tried Windows “Default Program”? You can read this if you don’t know how to open the “Default Programs” (this is for Windows 7) https://windows.microsoft.com/en-in/windows/change-default-programs#1TC=windows-7
    Click “Start” (Windows Logo on the taskbar), select “Default Programs”. A new window will open, now click “Associate a program or protocol with a program”. You’ll see the “loading” progress bar. Once it’s loaded, you’ll see a list of file types. Locate “.indd” and click it. Now, just above the list of file types, you should see a button “Change Program”, click it and change to InDesignxx (xx is your version of InDesign). Click “Ok” and close. Now restart your computer and see if this works. 🙂
    Good Luck!
