Activity Forums Adobe Premiere Pro Incorporating Flash Animation into Premiere Pro Movie
  • Incorporating Flash Animation into Premiere Pro Movie
    Posted by Jodi Engel on March 13, 2008 at 7:40 pm
    Does anyone know the best way to incorporate flash animation into a Premiere Pro movie?
    I am creating a presentation that needs to show web interaction activity – i.e. typing into a browser, showing what/where to click to get to a specific area of the website, etc. I thought it would be easiest to animate the typing/clicking portion using Flash and then import it into Premiere Pro to use within the movie presentation.
    In Flash, I am using a 30 fps rate. I am then exporting to a Windows AVI file with settings of:
    720 x 480 pixels (same as my Premiere Pro movie)
    16 bit color video format
    NOT compressing
    When I incorporate it into PPro and then export the entire sequence, the quality of the Flash portion isn’t very good and the animation isn’t smooth.
    Anyone have suggestions?
    Oh… I tried Quick Time, too, with even worse results.
    Thanks in advance!
    Jodi
    Perry Cheng replied 18 years, 6 months ago 4 Members · 9 Replies
  • 9 Replies
  • Perry Cheng
    March 13, 2008 at 9:52 pm
    https://www.swftools.com/tools-details.php?tool=1602070882
    swf2avi > import swf into this software, then export as tga sequences with transparency.
    Perry
  • Jon Barrie
    March 13, 2008 at 10:16 pm
    If the exports are the right frame rate and you render the file in PPro then it should playback properly. If not I’d say there is something not right in the export from Flash.
    – Jon 🙂
    How many editors does it take to change a light bulb?
  • George Socka
    March 14, 2008 at 12:47 am
    No need for other programs.
    In flash, export — movie, jpeg or or bmp sequence Jpeg works well enough for me.
    I would use 640×480 though, and let project PAR strech as required.
    George Socka
    BeachDigital
    http://www.beachdigital.com
  • Jodi Engel
    March 14, 2008 at 12:26 pm
    Thanks for everyone’s response and help! I’m off to give everything a try.
    Thanks, again everyone! 🙂
    Jodi
  • Perry Cheng
    March 14, 2008 at 9:44 pm
    The difference between using swf2avi vs not is “transparency”.
    Perry
  • Jodi Engel
    March 19, 2008 at 3:02 pm
    Well, I’ve tried everything, and nothing seems to be working well. Using the SwfAvi and converting to tga sequences would probably be ok if there weren’t so many frames (over 1000) – it just creates a HUGE file in the end.
    Would it be better to try to do it all in PPro? Does anyone know how – if it’s possible – to show the “typing” effect in PPro (i.e. one letter at a time coming on screen)?
    Thanks, guys…
    Jodi
  • Perry Cheng
    March 19, 2008 at 10:09 pm
    The files get huge? Each file is not that big, the reason you have so many because each file represent 1 frame. As far as doing the typing effect in PPro, I guess you can animate a keyframe with a track matte… You can do this easily with Premiere elements also.
    Perry
  • Jodi Engel
    March 20, 2008 at 1:12 pm
    Each individual file wasn’t so big, but when I got them into PPro, it just took about a half hour to render – when it finally finished and I played it back, it was really jumpy and flickered a lot. I tried importing them in both as individual images and then as a single clip (numbered stills), with the same result.
    Maybe my export settings are wrong?
    File Type = Microsoft DV AVI
    Compressor = DV NTSC
    Color Depth = Millions of Colors
    Pixel Aspect Ratio = Square Pixels (1.0)
    Bit Depth = Maximum
    It’s going to eventually have to be exported both for the Web and onto DVD, so I was trying to make it DVD-ready first to make sure the quality was good. If you have any suggestions, I’d greatly appreciate them. (I don’t know much about compressing and such, so I was just trying to go by the book.)
    I’m going to work on the track matte thing, now – thanks for that! Hopefully once I find a good solution, the rest of the video will go smoothly.
    Thanks for your help!
    Jodi
  • Perry Cheng
    March 20, 2008 at 4:56 pm
    Where are you seeing the jumpy and flickers? In preview windows? Windows Media Player? What’s your machine specs? Ever try to burn a test DVD to see if it is still jumpy? Could it have to do also with “interlace” problem?
    If you are rendering just the portion of the animation, it should not take 30min. Just couple. Perhaps you need to check or uncheck “Optimized Still” option in the general tab?
    Hope this help.
    Perry
