importing Kodak Zi8 footage to Sony Vegas
Posted by Justin L. on June 10, 2010 at 11:02 pmHey guys!
I’m looking to buy a handy/pocket size camcorders. And I really like the Kodak Zi8 a lot.
Only problem is, I saw a lot of complaints about importing the footage to Vegas because of its .mov format. Is there an easy way to fix this without buying any softwares??i really need your help so I’ll know what camcorder to buy.
Justin L. replied 16 years, 2 months ago 3 Members · 13 Replies -
John Rofrano
June 11, 2010 at 3:18 amIs there an easy way to fix this without buying any softwares??
I’ve read that it’s a simple matter of changing the extension from MOV to MP4 for this cameras output. This causes Vegas to decode it with it’s own h.264 decoder instead of letting Quicktime handle it.
I would try and get some sample footage from the camera and test it out before buying it. Maybe take a memory card to the store and shoot some footage and take it home to test.
In general, cheap h.264 cameras are a nightmare to edit and I would avoid them. Make sure you test for yourself on your PC before buying such a camera.
~jr
http://www.johnrofrano.com
http://www.vasst.com -
Justin L.
June 11, 2010 at 4:09 amIsn’t there a software that comes with the camera that lets you convert the footage (Media Converter)?
Justin L.
June 11, 2010 at 10:19 pmHey John!
Would this work fine? https://www.vimeo.com/2786898
Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
John Rofrano
June 11, 2010 at 11:06 pmYea, he’s just renaming the file which is what I read would work.
~jr
Kevin Mccarthy
June 12, 2010 at 5:02 amVegas 9 handles zI8 footage without having to change anything. I love it
Justin L.
June 17, 2010 at 5:07 amI got a footage. Tried the rename it software. I have sounds but no video! How?! Why?!
John Rofrano
June 17, 2010 at 3:00 pmI thought Kevin said it works without changing anything. Did you try that first? I have no idea what that software does. If using the native file doesn’t work just try changing the file extension to .mp4 without using any software.
~jr
Justin L.
June 17, 2010 at 4:49 pmI tried importing the .MOV file to vegas. The problem is, there is no video and audio. I then tried changing the .MOV to .MP4 with the software and without, there was audio but no video. I don’t know why.
John Rofrano
June 17, 2010 at 5:22 pmWhat version of Vegas do you have? Kevin said that Vegas Pro 9.0 should handle these files. Otherwise I don’t know why it’s not working for you.
~jr
