Activity › Forums › Apple Final Cut Pro › I’m getting WAY too many flash frames. Anyone else?
Posted by Robert Bracken on January 18, 2013 at 7:48 pmIt seems that when I hit the “e” key to add video at the end it’s creating a small flash frame.
My projects are littered with these and I’m lucky that most of my videos are less than 5 minutes. That makes finding them take less time.
Is anyone else having these problems?
Bret Williams replied 13 years, 8 months ago 5 Members · 11 Replies -
Jeremy Garchow
January 18, 2013 at 8:56 pmI have not seen this problem. But.
The timeline index, I would imagine, would be a good place to find these.
Are all of your clips the same frame rate?
Jeremy
Robert Bracken
January 18, 2013 at 10:11 pmYes I have snapping turned on.
But I’m pressing the “end” button to add video to the end. Why is fcpx giving me flash frames? -
Jeremy Garchow
January 18, 2013 at 10:13 pmis your footage the same frame rate as your timeline and is all of your footage the same frame rate?
Mike Damian
January 18, 2013 at 10:27 pmare you using MFX files by any chance? I’ve had problems with them creating black flash frames before. SO I had to convert to ProRes 422.
Robert Bracken
January 18, 2013 at 10:32 pmI don’t know what that is. I selected “optimized my clips” when importing.
Jeremy Garchow
January 18, 2013 at 10:40 pmIf you get a flash frame every time you hit e, you should try trashing your prefs or reinstalling.
Nick Toth
January 19, 2013 at 3:10 pmI was recently doing some audio editing with the source clip in the primary storyline and no other clips in the project.
I cut out a section and wanted to repeat it several times so I did what I would normally do and option-dragged the clip to make and place the duplicate. I kept getting one frame audio clips at the end of the option-dragged clip.
This is not normal behavior and I have not been able to follow up on it yet but maybe there is a bug in there somewhere and it’s related to what you’re seeing.
NT
