Activity › Forums › Apple Final Cut Pro Legacy › Ideal Quicktime to Show Client Prores 422 sequence?
Kevin Monahan replied 16 years, 12 months ago 5 Members · 13 Replies
Peter Dunphy
August 26, 2009 at 1:59 pmSolved this bad boy again thank God – when exporting as Quicktime file from FCP, I chose ProRes 422 1440 x1080.
I have a motion item that’s at the higher size (to be fixed later but time is of the essence now so I have to proceed with the QT export) so perhaps that was causing the seq to be funky.
2 x 2.66 GHz Quad-Core Intel Xeon, 8 GB 1066 MHz DDR3, ATI Radeon HD 4870, ATTO ExpressSAS R380, Sonnet D800 Raid 5
David Roth weiss
August 26, 2009 at 3:55 pm[peter dunphy] “I need to export a ProRes 422 edited sequence from FCP6 to show on Quicktime on an up-to-date Intel iMac (which doesn’t have FCP installed).
How might I get the best quality for the Quicktime file I’ll be previewing? “
Peter,
A self-contained QT using current settings, i.e. ProRes will play just fine on your client’s iMac if you have a transportable firewire drive to bring to their facility. You didn’t mention any limitations on file size in your initial post, just that you were looking for the best quality, and ProRes is the best, so why not really show them the best if you can?
David
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
Kevin Monahan
August 27, 2009 at 4:17 pmMake sure that the client has updated QT so that it can decompress the ProRes movies. QT handles ProRes even if FCS is not installed. This apparently works with PCs too.
Kevin Monahan
http://www.fcpworld.com
Author – Motion Graphics and Effects in Final Cut Pro
