Activity Forums Apple Final Cut Pro Legacy Ideal Quicktime to Show Client Prores 422 sequence?
  • Ideal Quicktime to Show Client Prores 422 sequence?
    Posted by Peter Dunphy on August 26, 2009 at 10:36 am
    Hi guys
    I’d appreciate any thoughts you can offer on my FCP6 question regarding exporting to Quicktime below.
    I need to export a ProRes 422 edited sequence from FCP6 to show on Quicktime on an up-to-date Intel iMac (which doesn’t have FCP installed).
    How might I get the best quality for the Quicktime file I’ll be previewing?
    Again, any thoughts appreciated, and thanks for reading.
    Warm regards
    Peter
    2 x 2.66 GHz Quad-Core Intel Xeon, 8 GB 1066 MHz DDR3, ATI Radeon HD 4870, ATTO ExpressSAS R380, Sonnet D800 Raid 5
    Kevin Monahan replied 17 years ago 5 Members · 13 Replies
  • 13 Replies
  • Peter Wiggins
    August 26, 2009 at 10:40 am
    H264 Play around with the compression/file size etc
    Select AAC audio too
    Peter
  • Peter Dunphy
    August 26, 2009 at 10:45 am
    Brilliant Peter thanks :o)
  • Peter Dunphy
    August 26, 2009 at 11:00 am
    Got my H264 created successfully and it looks great but the audio ‘clicks’ for me every couple of seconds.
    To play the file H264 file I had highlighted both the H264 file and the AAC 128Kbps.m4a file, right clicked and chose to open with Quicktime.
    I noticed that the H264 file originally seems to come with PCM sound – perhaps there is a way to remove the PCM sound as it might be conflicting with the AAC sound?
    Just noticed in H264 for audio there is enabled, disabled and passthrough – will tinker with disabled and passthrough. Am I on the right track?
  • Peter Dunphy
    August 26, 2009 at 11:11 am
    The AAC sound opens in a separate Quicktime player than the H264 Quicktime player for me.
    H264 has sound disabled – need a way of getting that good AAC audio onto the H264 file in the Quicktime player.
    Any quick tips would be really appreciated.
    All the best
    Peter
  • Peter Dunphy
    August 26, 2009 at 11:25 am
    BTW for speed I’m using a Quick Cluster (7 cores) in Compressor.
  • Peter Dunphy
    August 26, 2009 at 11:34 am
    Fantastic!
    Solved it! Noticed in Compressor in the Inspector for H264 that I can simply switch the audio from PCM to AAC without having to actually add in a new, separate AAC Setting.
    Can relax now! Hope you’re all having a great week and looking forward to Snow Leopard!
  • Peter Dunphy
    August 26, 2009 at 11:58 am
    Ach – still getting faint crackling when i play the H264 file in Quicktime.
    I exported the ProRes 422 movie as self-contained Quicktime file in FCP6.
    I dropped this file into Compressor, chose H264 and AAC audio (instead of the default PCM audio).
    Any tips about what I could do to solve this would be really appreciated.
    Warm regards
    Peter
  • Erik Lindahl
    August 26, 2009 at 12:21 pm
    What I’ve done when needing to send high-resolution review copies with short round-trip-times is to use the Photo JPEG codec at 50-75%. File sizes are larger than h264, but smaler than ProRes and the encoding time is faster than realtime. Playback also works on all systems with out hassel of installing a ProRes codec.
    Regarding crackling sounds I sadly can’t help… I tend to use QuickTime player for quick and dirty h264 output or Telestream’s Epsiode for “mastering” output.
    Erik Lindahl
    Freecloud Communication
  • Peter Dunphy
    August 26, 2009 at 12:48 pm
    Okay solved again – just put the AAC audio setting to Best.
    Now just one more problem – I have some fast sports sequences in my edit and they appear very blurry/tracey.
    Is there a way I can remove the blur please?
  • Peter Dunphy
    August 26, 2009 at 1:14 pm
    Thanks for your kind advice Eric
    Upon exporting from FCP to a self-contained QT a bad blurring/mild tracing effect during the fast moving sequences is already noticeable – I checked my export setting is correctly Top First and have fiddled with settings but still getting a blur during fast sequences.
