Activity › Forums › Apple Motion › I want text to be blown off the screen like dust.
Posted by Trevor Ward on April 6, 2005 at 7:24 pmI want to take the word “religion” and have the letters, starting with “n” to turn into dust and blown away by the wind. Can this be done in Motion? How?
-TrevorMark Spencer replied 21 years, 5 months ago 6 Members · 8 Replies -
Scot Walker
April 7, 2005 at 6:26 pmMaybe a combo of a particle generator combined with a blur wipe off?
Trevor Ward
April 8, 2005 at 3:06 amThere is no particle generator. There is a Library group called Particle Emitters. But that actually creates objects on the screen, it isn’t a behavoir. C’mon, doesn’t somebody know this answer? I found a Blur Fade Out that will almost do what I want it to. As each letter is bluring and fading out, I’d also like it to sort of disperse and scatter away from the word it just came from.
Peter Wiggins
April 8, 2005 at 11:28 amYou’ve tried the wind text behavoir?
That makes the letters drift offPeter
Trevor Ward
April 8, 2005 at 12:05 pmI tried adding a parameter to the Blur Fade out, tracking, this makes the letters move away from the word. I’m gettng closer. However, it more looks like the words turn into smoke and then get blown away. I need dust, not smoke.
The wind isn’t actually a text behavior. It’s a parameter behavior and it just makes the whole word move in a direction, similar to throw.
What about LiveType?
Peter Wiggins
April 8, 2005 at 2:39 pm[Trevor Ward] “The wind isn’t actually a text behavior. It’s a parameter behavior and it just makes the whole word move in a direction, similar to throw. “
FYI Gust of Wind is a Text Sequence in the Behavoirs folder
Peter
David Bogie
April 8, 2005 at 11:14 pmAfter Effects.
Shatter.
Incredible recipe for just exactly this effect.Can’t be done without a particle system that takes an alpha input
bogiesan
Philip Hodgetts
April 8, 2005 at 11:35 pmThere’s a tutorial out there somewhere that might help get started – search google for – motion, creating explosive particle effects – and you should find it. It uses particles to wipe out an object. If you did something like this with a sand-like particle, and used that to wipe off the existing text and overlaid a blowing particle like other people have suggested, you could get close.
Cheers
Philip Hodgetts
https://www.proapps-hub.com
The ProApp-Hub: The convenient way to the best of what’s free and everything else you need to be productive and creative with Apple’s Professional audio and video ApplicationsDownload Now proapps-hub
Mark Spencer
April 10, 2005 at 5:16 amCheck my site, all online tutorials are listed there – check “blowing things up”.
Mark Spencer
Freelance Editor/Producer
Apple-certified instructor, Final Cut Pro and Motion
Author, Motion Visual Quickstart Guide from Peachpit Press (coming soon)
https://www.applemotion.net
