Activity Forums Apple Final Cut Pro I have subtitles in FCP X. Best current way to create an SRT file?
  • I have subtitles in FCP X. Best current way to create an SRT file?
    Posted by Noam Osband on May 12, 2023 at 8:51 pm
    Simple question. But I worry the answer isnt simple. I have subtitles and need to make a SRT file for Youtube. (I don’t want to use Youtube automated subtitles cause the language is not easy to make out).
    What’s the best way to make an SRT file?
    Doug Metz replied 3 years, 3 months ago 2 Members · 1 Reply
  • Doug Metz
    May 12, 2023 at 10:15 pm
    How do you have your subtitles in FCP?
    If they’re already captions, you can easily reassign them: Default is iTT – right-click one of your captions on the timeline, Edit Roles…, add SRT (close), right click again and reassign to SRT. Then when you export your project, you’ll select your SRT Caption output on the Roles tab of the Export panel.
    If your subtitles are actually text generators, that’ll be a bit more tedious.
