Activity Forums Apple Final Cut Pro Legacy HVD to Prores via Firewire
  • HVD to Prores via Firewire
    Posted by Michael Allen on February 20, 2009 at 6:24 pm
    Do I need an array to capture HVD to Prores via Firewire? Will a firewire 800 drive be fast enough? The kona system test says I am getting 180 MB/s read-write speed with my current setup, will this get the job done? How much throughput do I really need?
    I will update my FCP to a version that will allow Firewire to Prores soon, otherwise I could just check this myself. I can’t at this point in time, so I thought I would ask the professionals.
    Mike
    David Roth weiss replied 17 years, 7 months ago 2 Members · 1 Reply
  • David Roth weiss
    February 20, 2009 at 7:01 pm
    [Mike Allen] “Do I need an array to capture HVD to Prores via Firewire?”
    Nope.
    [Mike Allen] “The kona system test says I am getting 180 MB/s read-write speed with my current setup, will this get the job done?”
    Yep!
    [Mike Allen] “How much throughput do I really need? “
    Capturing HDV to ProRes via firewire is not at all throughput (hard drive) intensive, and editing ProRes was designed to make HD possible using single firewire 800 drives. So, since you’re obviously using a firewire 800 in a raided configuration you’re doing just fine.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
