Activity › Forums › VEGAS Pro › How to correct chromatic aberration with Vegas ?
  • D. Eric franks
    October 23, 2009 at 3:42 pm
    Just about anything that can be isolated can be fixed, but I can’t think of a way to fix something as complex as chromatic aberration. Still, you never know: Can you post a screen grab here of what you are trying to fix? I know the folks here love a good challenge.
  • Roberto Mettifogo
    October 23, 2009 at 5:03 pm
    It’s a simple chromatic aberration. The solution in photography is very simple and available in almost any picture editing software, I just wonder why both After Effects and Vegas don’t have something for that… btw this is a typical CA problem https://www.tlc-systems.com/pp011185crp.jpg
  • D. Eric franks
    October 23, 2009 at 6:51 pm
    My background is technical, so the extent of my knowledge on chromatic aberration is limited to optics, but if photo editing apps can fix it, the Premiere/After Effects should be able to fix it, since many/most/all? Photoshop filters are available in those apps as well. Can the example image you posted be corrected in Photoshop?
  • Theo Van laar
    October 23, 2009 at 11:39 pm
    The best results I got for removing the chromatic abberation in this example footage using Vegas is to take the information of the red channel of the footage to create new Red, Green and Blue channels (see figure). (Please note that the result is this way looks much better then when the Green or the Blue channels were used. Also applying the Black and White FX is not giving satisfating results).
    Theo
  • Theo Van laar
    October 23, 2009 at 11:51 pm
    And if you wish you can bring back some of the sharpness using the convolution kernel FX
    Theo
  • Theo Van laar
    October 24, 2009 at 12:01 am
    To further improve the image, you can duplicate the track and apply the HARD LIGHT composition mode (see figure).
    Theo
  • Theo Van laar
    October 25, 2009 at 10:31 am
    And this is how the original looks:
    Theo
  • Roberto Mettifogo
    October 25, 2009 at 2:56 pm
    how can I remove CA from a color footage? isn’t there any payware plugin that works like color correction in photoshop or lightroom?
  • Theo Van laar
    October 25, 2009 at 4:01 pm
    Roberto,
    Did you get good results with the footage you uploaded?
    Theo
  • Roberto Mettifogo
    October 25, 2009 at 4:52 pm
    that was just an image taken from internet to show what CA is all about.. btw I tried with some color footage and no success… I will upload a one second clip I just made in few minutes, maybe if you or someone else can do the correction and put the project file online it would be cool…
Page 1 of 3
