How to correct chromatic aberration with Vegas ?
Fred Robinson replied 16 years, 1 month ago 4 Members · 21 Replies
Roberto Mettifogo
October 25, 2009 at 5:10 pmOk this is a sample file I just did:
https://www.robertomettifogo.com/stuffbox/zip/chromatic-aberration.zip
A you can see the wide angle adapter caused some CA on the airplane’s nose (green) and on the right side of the elevator (red).
Can you do a project file with the correction and post it?
Thanks -
Theo Van laar
October 25, 2009 at 11:21 pm -
Theo Van laar
October 25, 2009 at 11:23 pm -
Theo Van laar
October 26, 2009 at 7:15 am4 times the Chromablur FX (three times might also be OK depending on your wishes and the rest of the footage). And I masked the red wires out (that’s why I was asking whether it is a static shot or a moving camera).
Please inform us about the results you get…
Veg file:
343_chromaticaberation.veg.zip
Theo
Roberto Mettifogo
October 26, 2009 at 9:34 amAh ok I tried chromablur already but it doesn’t totally eliminate CA, and it affects also other colors of the video..
My videos are always moving (aerial videos).
Thanks for suggestions -
Theo Van laar
October 26, 2009 at 1:58 pm‘Ah ok I tried chromablur already but it doesn’t totally eliminate CA,’
That’s why I used 4 copies of the Chromablur FX….
‘and it affects also other colors of the video.. ‘That’s why I included some masking around the red-colored wires…
You didn’t look at the project-file yet?As you have seen in the 2 examples above, it depends very much on the footage whether CA can be repaired and how it can be done. So without having seen the rest of the footage, I can’t say anything about it.
Theo
Roberto Mettifogo
October 26, 2009 at 4:55 pmI didn’t see it yet but I know what you’ve done, I do aerial videos over natural landscapes and cityscapes, CA is everywhere, video is always movine, I need photoshop like plugin. Using a fixed focal lenght lens it would be very easy to correct but so far I did’t find any plugin with two sliders to effectively correct CA like we do in Photoshop or similar..
