Activity Forums Maxon Cinema 4D how do i use a delay effector (essentially spring) on a normal SRT animation?
  • how do i use a delay effector (essentially spring) on a normal SRT animation?
    Posted by Manojit Ghose on April 17, 2012 at 9:51 am
    hi everyone!
    as the subject says, anyone knows a simpleway to do it…without xpresso (unless that’s the only way)
    thanks
    m
    MG
    Adam Trachtenberg replied 14 years, 5 months ago 2 Members · 9 Replies
  • 9 Replies
  • Adam Trachtenberg
    April 17, 2012 at 12:56 pm
    Drop your animated object into a mograph>fracture object and apply the effector to the fracture object.
  • Manojit Ghose
    April 17, 2012 at 1:03 pm
    works! thanks a ton.
    MG
  • Manojit Ghose
    April 17, 2012 at 1:08 pm
    okay however i am facing a adverse effect on my sound in the timeline now…
    sound gets weird as soon as i drop a mograph generator (like fracture) or an effector such as delay…
    i got the sound via an effector “sound” and called in the file and allowed it to play on timeline.
    thanks
    m.
    MG
  • Adam Trachtenberg
    April 17, 2012 at 1:18 pm
    That’s weird. Not sure what’s going on there.
  • Manojit Ghose
    April 17, 2012 at 1:20 pm
    i tried out getting rid of generators/effectors.
    and the culprit seems to be the fracture. once i get rid of it the sound is good again!
    thanks
    m
    MG
  • Manojit Ghose
    April 17, 2012 at 3:13 pm
    one catch,
    the object i am using this delay/spring is also used as a cloner object to assign those cylinders and spheres.
    so when the fracture+delay effector work. it works on top of the animation. but i cant seem to get the position of my cloned objects adhere to the deformed parent object’s vertices and edges.
    any workarounds?
    thanks
    m.
    MG
  • Adam Trachtenberg
    April 17, 2012 at 10:25 pm
    I’m not sure I understand. Can you post a scene, or at least a screenshot of your object manager?
  • Manojit Ghose
    April 18, 2012 at 8:24 am
    hi,
    sure here is the file:
    https://dl.dropbox.com/u/7646657/sphereMG_v01.03.rar
    thanks
    m
    MG
  • Adam Trachtenberg
    April 18, 2012 at 1:12 pm
    Okay, I think the solution is to take the object you’re using as a clone target out of the Fracture Object. It looks like the Fracture doesn’t serve any purpose except to mess up the cloners.
