How do I rip DVD to the vegas timeline?
Posted by Frank Manno on May 21, 2007 at 9:40 amIs it possible to rip a DVD movie to the vegas timeline? I can’t seem to get vegas to ‘see’ the files in the AUDIO_TS and VIDEO_TS folders on the DVD movie.
We’re doing a send up of the Godfather and it would be easier if I could get the movie on the timeline as a reference. (scene length, dialogue etc)
Would also like to match colour to it etc..
-Frankie
Pisceansailor replied 19 years, 4 months ago 8 Members · 15 Replies -
Frank Manno
May 21, 2007 at 2:17 pm>File – Import – DVD Camcorder Disc
I don’t have that.. Am using 6.0b. Is this something new?
-Frankie
Don Bloom
May 21, 2007 at 2:36 pmHMMMM< I thought the FIle>Import>DVD Camcorder Disc feature showed up on all of Version 6 but it MIGHT have been added to 6d-if for some reason it’s not there you can hookup a DVD player to your passthru, be it a deck or camera and simply play the DVD into your computer using Vegas capture or Scenalayzer and now you have an AVI to work with instead of an MPEG. I have found it easier to do that so I don’t need to goof around with converting.
Don
Edward Troxel
May 21, 2007 at 3:14 pm -
Terry Esslinger
May 21, 2007 at 3:25 pmHow does the copygurad issue affect this. Not legally but functionally?
Edward Troxel
May 21, 2007 at 3:28 pm -
Mike Kujbida
May 21, 2007 at 9:45 pmEdward is right so you won’t be (legally) able to rip a Godfather DVD.
Frank Manno
May 22, 2007 at 12:35 am>you can hookup a DVD player to your passthru, be it a deck or camera >and simply play the DVD into your computer using Vegas capture or >Scenalayzer
Is it possible to do this? I find that with vegas capture I can’t capture anything via a passthrough because I can’t find any way of starting a capture this way. Vegas seems to want to control the deck to start a capture, via deck control.
How can I start capturing a signal that’s just passing through my firewire deck?
-Frankie
Mike Kujbida
May 22, 2007 at 12:44 am“How can I start capturing a signal that’s just passing through my firewire deck?”
In the Capture window:
Options – Prefs – General:
De-select Enable DV device control. -
Mike Kujbida
May 22, 2007 at 12:47 am…hookup a DVD player to your passthru…
Be advised that, if the DVD is copy protected, this won’t work.
