Activity Forums Apple Final Cut Pro Legacy How do I rip a DVD into A High Quality file to use in FCP?
  • How do I rip a DVD into A High Quality file to use in FCP?
    Posted by Richard Pengelly on November 5, 2010 at 2:32 am
    I have a DVD that I need to use in one of my edits. The dvd is not copyright protected. I have handbrake and I work on a cruise ship so downloading another app is too expensive because of the speed of the internet. I could potentially down load an app in one of our ports.
    If handbrake will work what are the settings I should use?
    Funkin it up Old School
    Ken Pugh replied 15 years, 10 months ago 5 Members · 6 Replies
  • Shane Ross
    November 5, 2010 at 4:28 am
    DO NOT USE Handbrake. It is not meant to rip DVDs to editing codecs. Use MPEG STREAMCLIP, and encode to DV50 (also known as DVCPRO 50).
    Shane
  • Thomas Morter-laing
    November 5, 2010 at 9:59 am
    I use mpeg streamclip and set it to transcode to Prores 422- at max quality you’ll be looking at some big files though!
    Tom Morter-Laing
    Certified Apple Product Proffessional, 2010
    Degree; TV Production
    iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800).
  • Scott Sheriff
    November 5, 2010 at 4:07 pm
    Tom
    IMHO, ProRes HQ is total overkill for material taken from DVD’s. It’s probably overkill for 99% of what most folks are cutting.
    In the case of a ripped DVD, there is only so much information to be had from the source, and standard ProRes easily exceeds this. As you noted ProRes HQ results in really big files, which is really the only extra you will get over standard quality ProRes.
    Scott Sheriff
    Director
    SST Digital Media
    https://www.sstdigitalmedia.com
    November 5, 2010 at 4:27 pm
    I didn’t say HQ, I meant with mpeg streamclip set to maximum quality. 🙂
    Tom Morter-Laing
  • Scott Sheriff
    November 5, 2010 at 6:24 pm
    Tom
    My bad, thought you meant ProRes HQ.
    Scott Sheriff
    Director
    SST Digital Media
  • Ken Pugh
    November 5, 2010 at 7:00 pm
    If quality is not absolutely paramount – try DVDxDV and transcode to a DV file, small download and quite cheap!
    Ken.
