Activity Forums VEGAS Pro How can I set up dual display?
  • How can I set up dual display?
    Posted by Leonard Johnson on April 2, 2010 at 2:43 pm
    I’m currently using a duel display setup with sony vegas 9.0 platium. Can I edit on one display and preview on another? I thought I could do that.
    Leonard Johnson replied 16 years, 4 months ago 2 Members · 2 Replies
  • Steven J casey
    April 2, 2010 at 6:58 pm
    I’m not sure about Platinum. In Pro you just grab the left edge of the window, the side with the dots, to undock, then drag wherever you want it. Under the View menu you can save your layout configurations for easy call up later. Again, this in Pro, not sure about Platinum.
  • Leonard Johnson
    April 8, 2010 at 1:15 pm
    Thanks alot! That was simple enough.
