Activity › Forums › Adobe Premiere Pro › Hooked up Z1U to Prem Pro 1.51, doesn’t work
Steve Slocomb replied 21 years, 4 months ago 4 Members · 12 Replies
Steven L. gotz
April 23, 2005 at 11:30 pmAnd you know to change the HDV conversion off when trying to capture HDV?
Try downloading the Cineform HDLink software. If that does not work, you have a problem with your camera and not Premiere Pro.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Steve Slocomb
April 25, 2005 at 6:28 pmI guess the camera must be bad…I tried the Connect HD software and it doesn’t see it either. I turned off all the HDV to DV conversion settings in the camera (when operating as a VCR). In fact I have tried all the combinations conceivable. If I had access to another camera or a deck I could verify the problem. It is hard to believe that the device control works for DV projects and not HDV.
