Activity Forums Adobe Premiere Pro Hooked up Z1U to Prem Pro 1.51, doesn’t work
  • Hooked up Z1U to Prem Pro 1.51, doesn’t work
    Posted by Norman Lafranchi on April 19, 2005 at 12:32 am
    When I create an HDV project and then go to catpure, it says, “Capture device offline”.
    I followed the instructions for the installation, and the camera is hooked up and in HDV mode. I installed SP 2 and 1.51. Is there something I’m missing? Besides the camera?
    Steve Slocomb replied 21 years, 5 months ago 4 Members · 12 Replies
  • 12 Replies
  • Steven L. gotz
    April 19, 2005 at 1:11 am
    1. The little blue LED is on next to the HDV label above the firewire connection?
    2. Your preferences are set for Device Control to “HDV Device Control”?
    3. Your settings in the Capture window are also set to “HDV Device Control”?
  • Norman Lafranchi
    April 19, 2005 at 1:12 am
    I got it… it’s a camera setting. It was set to “Convert HD to DV”.
  • Mickavid
    April 19, 2005 at 8:28 pm
    Which codec are you using? I have to purchase the whole outfit (ppro 1.5, the hd codec, Sony Z) and would like to know which one you have and how it works. Also, are you using adobe’s dvd program? Any glitches at all? Is it relatively quick? I have used fcp to go to dvd before – is this similar?
    Can you send me any info on your workflow and issues that you have encountered? mickavid@hotmail.com
    Mick
  • Steven L. gotz
    April 19, 2005 at 8:32 pm
    I highly recommend Cineform Aspect HD to go along with Adobe Premiere Pro 1.5.1
    Adobe Encore is a fine way to author DVDs.
  • Steve Slocomb
    April 22, 2005 at 3:51 am
    I have the same problem not seeing the camera, and have tried everything except upgrade to SP2–do I need to do that?
  • Steven L. gotz
    April 22, 2005 at 2:24 pm
    Yes. The HDV drivers for the Sony are in SP2.
    But then you may need to upgrade to the latest MainCOncept and Microsoft patches for SP2.
    https://support.microsoft.com/?kbid=886716&SD=tech
    https://www.mainconcept.com/adobemedia/downloads.html
  • Steve Slocomb
    April 22, 2005 at 4:48 pm
    thanks..I am taking baby steps towards editing this format.
  • Steve Slocomb
    April 22, 2005 at 6:50 pm
    I just installed SP2 and the updates and rebooted but it still doesn’t work. I have the camera set to output HDV and all the settings in the HDV project are set to HDV. However when the camera is set to convert the HDV to DV, the capture works fine (eliminating cable issues, etc)
  • Steven L. gotz
    April 22, 2005 at 7:00 pm
    There are three places to check. Your Device Control in Preferences, and then two in the capture window. One is the Capture Settings toward the top of the Settings tab, and the other is the Device Control at the bottom of the Settings tab.
  • Steve Slocomb
    April 23, 2005 at 4:15 pm
    All those 3 settings were correct, still no go. Everything works fine except for HDV capture. I can control the camera and digitze into a HDV project with the HDV to DV turned on in the camera, and use either Matrox or DV capture device controls.
