Activity › Forums › Adobe Premiere Pro › Highest Quality Export Settings for a backup video file please?
Posted by Kimberley Whytte on April 25, 2017 at 7:15 amWhat’s the Highest, and the Second Highest Quality Export Settings for a backup copy of the video file please?
premiere 2017 windows 10source file 1080p .mov
24 fps
low compression
video Overall bit rate : 88mb
16:9
audio Bit rate: 1 500 kb/sKimberley Whytte replied 9 years, 5 months ago 5 Members · 16 Replies -
Jon Doughtie
April 25, 2017 at 3:00 pmYou could create a Quicktime animation file, with no compression at all. The files, predictably, can be gi-normous.
Alternatively, go with a lossless, lightly compressed format like one of the Avid DNxHD codecs. You may have a slightly less gi-normous file.
System:
Dell Precision T7600 (x2)
Win 7 64-bit
32GB RAM
Adobe CC 2015.02 (as of 6/2016)
256GB SSD system drive
4 internal media drives RAID 5
Typically cutting short form from HD MP4 and P2 MXF. -
Kimberley Whytte
April 25, 2017 at 4:28 pmHi Jon,
I have installed Avid DNxHD from https://cdn.avid.com/Codecs/LE/2.7.3/0B9447EC/CodecsLE_2.7.3_Win.zip
and I cannot seem to see the option within Premiere 2017 11.1.0(222) Build in windows 10
I don’t know what went wrong.
Any tips to be able to see that option ” Avid DNxHD codecs” within premiere please -
Ole Kristiansen
April 25, 2017 at 5:21 pmAfter install DNxHD codecs you have to restart your computer – In Premiere the DNxHD are under Quicktime !
Jeff Pulera
April 25, 2017 at 8:57 pmYou don’t need to install any AVID codecs with Premiere CC 2017, the DNxHD codecs (.mxf) are built-in already
Jeff Pulera
Safe Harbor Computers -
Kimberley Whytte
April 26, 2017 at 5:04 am -
Jeff Pulera
April 26, 2017 at 2:06 pm -
Kimberley Whytte
April 26, 2017 at 7:31 pmThank you Ole Kristiansen.
Let me see if I could apply that onto mine
all the best -
Kimberley Whytte
April 26, 2017 at 7:33 pmThank you Jeff,
I have that.
what do I select after selecting DNxHD please
all the best -
Jeff Pulera
April 26, 2017 at 8:42 pmSelect a Preset to match the footage, for instance DNxHD HQ 1080p 29.97 are whatever matches. Don’t be intimidated by the 100+ presets. One of those at top of list should be fine, the rest are for higher bit-depth, or 4K, etc.
Jeff Pulera
