Activity › Forums › Adobe After Effects › HiDef output with After Effects
  • HiDef output with After Effects
    Posted by Gary Frewin on August 31, 2012 at 7:22 am
    I have a film that I rendered from Premier using the widescreen 720P setting, it’s frame size is 1920×1080. I cannot for the life of me get it to render in high quality from After Effects.
    I can select H264blueray, which will at least give me a hi def video (for youtube) but no sound, and nothing recognises the m4v filetype. Or I can try h264, and it forces me to shrink the video down to 720×480 and it looks terrible.
    How can I get an mp4 file in hi-def??
    Please help, I have a deadline today and I’ve been up all night trying to sort this problem. :`(
    Gary
    Tudor “ted” jelescu replied 14 years ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    August 31, 2012 at 7:47 am
    Clarify one thing please: you say 720p, but then the frame size 1920×1080…? Which is it 1280×720 or 1920×1080?
    You can render out of AE either using the render queue or using Adobe Media Encoder.
    What I do is to render an uncompressed version from AE (QT Animation)- for audio, make sure you have the Audio option checked in the Render Settings. I then use Encoder to compress that file. You can find several presets for YouTube. H264 preset works great for YouTube.
    You can open the AE project in Encoder, select the Comp you want rendered and choose the preset. This way you can compress and render at the same time, using the Variable 2 pass option that Encoder has and the AE renderer does not offer.
    Tudor “Ted” Jelescu
    Senior VFX Artist
