Help with 3d text reflection…
Posted by Josh J. johnson on January 25, 2007 at 4:48 pmI’m following this https://forums.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=41&page=https://www.creativecow.net/articles/okerstrom_jon/reflections/index.html
When I turn on use comp camera in AE and I move my cursor on the timeline my text stays in one spot? it doesnt stay in frame like my 2d text did? It’s not because I have 3d layer turned off right? John says to turn it off.
Jon Okerstrom replied 19 years, 7 months ago 2 Members · 11 Replies -
Josh J. johnson
January 25, 2007 at 8:29 pmIs it becasue I dont have Invigorator I just have proanimator? Otherwise I don’t get it.
Jon Okerstrom
January 26, 2007 at 1:52 amHi Josh,
The example was done in Invigorator, but ProAnimator can work too, so long as you abide by the basic rules about animated objects from each copy of the effect not crossing the eachother.
If you want, send me your project file and I can take a look at it.
jokerstrom1 (at) mac.com.
Jon
Josh J. johnson
January 26, 2007 at 3:36 pmI sent you my project my email is johnsonjosh23@hotmail.com. My main problem is having my computer cameras follow my 3d text and having my 3d text in the z-axis since you said not to turn on the 3d check box in AE. Thank you very much for taking a look at it!
Jon Okerstrom
January 27, 2007 at 2:14 amJosh,
When you tell ProAnimator to use the comp camera, it works when that camera is the active view. When you’re using another view, you won’t see the movement you may expect.
Hope this helps.
Jon
Josh J. johnson
January 27, 2007 at 3:22 amPretty sure the camera is active view…I’ll have to double check it. I sent you my project file.
Jon Okerstrom
January 27, 2007 at 6:42 amHi Josh,
You have two cameras in there — not sure why. If I get a chance, I’ll work up a PA version of my reflection project to see if that helps.
Jon
Josh J. johnson
January 27, 2007 at 9:55 pmI’ll have to check it out monday at work I don’t have a computer set up at home yet but I do have all the software just looking for a good computer. That is probally the problem the two cameras. Thank You, if you have time for pa that is fine if not it is ok.
Josh Johnson
Manager of Video Production
ETC, Inc. -
Josh J. johnson
January 31, 2007 at 4:32 pmJust wanted to say thanks for all your help Jon. I’m having a problem now where my text seems to actually move as my camera does? I sent you an email with my ae project attached if you get time to look at it. Thank You
