Activity Forums Zaxwerks Help with 3d text reflection…
  • Jon Okerstrom
    February 1, 2007 at 1:58 am
    Glad you figured it out. I sent an example project to you with PA rather than Invigorator.
    Some general tips: It’s important that you set up both PA layers on the front view, then click the use comp camera option. Otherwise, it’s just too hard to keep track of what’s happening. Also be very aware of keeping the movement of the layers from intersecting. The simplest way is to keep the movement in the one half of 3D space.. above the zero line for the normal layer and below it for the reflection layer.
    Jon
Page 2 of 2
