Activity Forums Apple Final Cut Pro Legacy Hearing Audio durring logging and capturing
  • Hearing Audio durring logging and capturing
    Posted by David Sandbank on July 13, 2005 at 1:49 pm
    It drives me nuts that in FCP I can’t hear the audio when capturing. Other than using the audio out on my deck is there any way in FCP to hear the audio through firewire?
    David Sandbank
    G5 Dual FCP 4.5
    Kirk Weston replied 20 years, 11 months ago 5 Members · 5 Replies
  • Bouncing Account needs new email address
    July 13, 2005 at 2:03 pm
    BTW, this is a VERY FAQ.
    You can find nearly “instant” answers to many questions by just using the SEARCH POSTS on the COW.
    The audio is, by default, MUTED to the Mac’s speaker output during Log and Capture.
    You should normally monitor the audio directly from the camcorder or deck you are using to capture.
    NOTE:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing… so may want to choose “Off During Capture.”
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to:
    Final Cut Pro (menu) > Audio/Video Settings… > Capture Presets (tab)
    “Duplicate” the Capture Preset you are now using, when the window opens rename it (I added “MacAudioOn” to the file name).
    Click open the “Advanced” button in the Audio section and turn speakers to “ON during Capture.”
    The Mac speakers/audio-out will now play Audio during the preview in the Log and Capture window.
  • David Sandbank
    July 13, 2005 at 2:16 pm
    thanks.
    david
  • Dave Kulawick
    July 14, 2005 at 1:41 pm
    Why do you say “You should normally monitor the audio directly from the camcorder or deck you are using to capture.”
    It has always been my practice to monitor the recording device, whatever it is.
    “NOTE:
    Many people have reported that noise or “pops” appear in the captured clips if the Mac’s internal audio is left on WHILE capturing.”
    That sounds like a bug to me, but almost explains why one has create a new capture preset to enable audio monitoring during capture.
  • Tom Wolsky
    July 14, 2005 at 1:51 pm
    The computer’s internal audio is 44.1, the audio CD standard. That’s the problem. The processor has to resample the audio on the fly to play back the sound through the speakers, while it’s capturing at what’s most likely a different sampling rate. This is a bad idea. In older systems it was buried in capture presets because slower processors would actually cause sync drift during capture. That’s what Ralph Fairweather found when he was QA for the original Final Cut Pro. Modern systems with faster processor speeds probably don’t have this problem, but I could well see it causing odd sound problems though. I don’t see the point of risking it myself.
  • Kirk Weston
    September 6, 2005 at 12:57 am
    And the third option is to select ‘OFF while recording’ in the Advaced tab. This allows you to still hear the audio through computer speakers while logging clips.
