Activity › Forums › Apple Final Cut Pro Legacy › HDV problems AGAIN!!!!!!
David Roth weiss
February 18, 2009 at 5:29 pm[Chris Borjis] “David, are you saying my quad G5 which drops frames and cancels capture within
10 seconds when I try to capture HD 1080 ProRes will actually succeed if it’s
over a firewire connection? “Hell yes!!! It works flawlessly on my dual 2.3Ghz G5.
Capturing to ProRes on the fly via firewire does not work like any other capture method, as it automatically captures first, then transcodes the material in the background, in something slightly slower than realtime. The interface actually displays information that tells you that the process is something like 25% or 30% behind the capture process, as it warns you not to bail out when the the tape gets to the end.
David Roth Weiss
Director/Editor
David Weiss Productions, Inc.
Los AngelesPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
David Roth weiss
February 18, 2009 at 5:31 pm[Forrest Love] “Hells no.”
Would you like to make a small wager?
David Roth Weiss
Director/Editor
David Roth weiss
February 18, 2009 at 5:34 pm[Chris Borjis] “I’m still running 6.01 so I don’t have that capture preset/capability yet.
was that first offered in 6.02? “I do believe it is possible that it was released in 6.0.2, so you might be SOL Chris.
David Roth Weiss
Director/Editor
David Roth weiss
February 18, 2009 at 5:37 pm[Forrest Love] “Via FW drive or deck?”
HDV tape to hard drive via Firewire.
Forrest, you simply have to read the tutorial… That’s all there is to it.
https://forums.creativecow.net/thread/8/1022337#1023349
David Roth Weiss
Director/Editor
Forrest Love
February 18, 2009 at 5:46 pmI did, thanks for the link, it’s only Wed and this HDV issue is killing me, on a week old MacPro, at least I’m doing P2 tomorrow.. Thanks to all of your for your input.
FML -
John Totterdell
February 19, 2009 at 6:19 pmLooking for best way to down-convert HDV captured clips to DV Pal.
Is exporting / edit to tape from TL an option or is it best to recapture in DV ?? Thanks -
Sergio Ornelas
May 10, 2010 at 6:56 pmForrest,
When you bring up your Log and Capture, click on the Clip Settings and uncheck “Create new clip on Start/Stop.
