Activity Forums Adobe After Effects Greenscreen editing assistance needed
  • Greenscreen editing assistance needed
    Posted by David Goodwin on February 13, 2015 at 3:46 pm
    Hello, I’m a bit of a beginner with After Effects and I’m trying to key out the background for this video. I attach a still of the original shot. As you can see the problem is the original footage isn’t as clear as I expected despite HD camera and the greenscreen is so badly wrinkled I can only pull a half decent key. Any advice on how to correct this? I used the preset Keylight spill suppressor and modified the values.
    This is the original:
    8552_alexcam2.jpg.zip
    The result is grainy and takes fragments out of the foreground and vice versa.
    Any help would be appreciated, thanks
    Kevin Reiner replied 11 years, 6 months ago 2 Members · 1 Reply
  • Kevin Reiner
    February 16, 2015 at 9:37 pm
    I agree with everything Dave has said. It’s just a really bad image. What camera are you shooting with and what settings? It looks like you had to really bump the ISO to get an image, which introduces a ton of noise. You need more light and need to put more distance between subject and background. If you are on a DSLR, be sure to do a digital zoom-in to check your focus. Hope you can reshoot, because that will be difficult to fix in post.
    Mac Pro 2 x 3 GHz 6-Core Intel Xeon
    32GB Memory
    Dual-channel 4Gb Fibre Channel PCI Express card
    Dell Display (23″ flat panel)
    Nvidia Quadro 4000
    AJA Kona LSi SD/HD capture card
    Rourke 16 TB
    Flanders 2460
    SOFTWARE
    Mac OS X 10.8.4
    FCP 7
    Premiere CC
    After Effects CC
    Boris Continuum
    Sapphire Plug Ins
    All Trapcode Plugs
    Zaxwerks Invig
