Activity › Forums › Adobe After Effects › Glitch when using Deblur
  • Glitch when using Deblur
    Posted by Chris Jordan on August 1, 2018 at 11:11 pm
    Hello, I’m getting this weird glitch where part of the blue banner for “Analyzing in Background” is rendered in the image in both the working preview and the final render.
    Here’s a screenshot: https://imgur.com/a/L7QWV1y
    The project is in 16-bit
    I’m using warp stabilizer with detailed analysis turned on at 5% smooth motion, changing the method doesn’t affect the artifact.Camera-shake deblur is set to 9 frames, high quality, and 120% strength, although changing anything but strength doesn’t affect the artifact. Lowering the strength, reduces the artifact.
    I’ve tried clearing all cache, restarting AE and the iMac, I can’t seem to get rid of it while keeping the Deblur effect. Is there something I’m doing wrong or can anyone else verify if this is a glitch?
    View post on imgur.com
    Chris Jordan replied 8 years, 1 month ago 3 Members · 15 Replies
  • 15 Replies
  • Michael Szalapski
    August 2, 2018 at 1:07 am
    What, exact, version of AE are you using?
    Have you tried clearing your caches?
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Michael Szalapski
    I meant, clearing ALL the caches. I know you did at least the basic one.
    – The Great Szalam
  • Chris Jordan
    August 2, 2018 at 9:03 pm
    CC 2018, I’ve cleared all memory and disk cache, are there other cache files elsewhere?
  • Chris Jordan
    August 2, 2018 at 9:04 pm
    Sorry, exact version is 15.1.1 (build 12)
  • Michael Szalapski
    August 3, 2018 at 1:41 pm
    Have you considered updating? You’re missing a number of bug fixes in the recent update.
    – The Great Szalam
  • Chris Jordan
    August 3, 2018 at 9:09 pm
    I’ll update and report back, thanks!
  • Chris Jordan
    August 3, 2018 at 9:36 pm
    Unfortunately, the problem persists. Are there any other methods of reducing motion blur on a stabilized shot?
  • Michael Szalapski
    August 8, 2018 at 1:05 pm
    If you don’t use Camera Shake Deblur, the banner doesn’t show up, right? Warp Stabilizer works fine, right?
    If so…maybe removing the Camera Shake Deblur effect, copying and pasting the layer into a new comp, and then applying a new instance of the Camera Shake Deblur effect will work.
    – The Great Szalam
  • Richard Garabedain
    August 8, 2018 at 6:04 pm
    should have just done the obvious and rendered and imported that video clip
  • Chris Jordan
    August 8, 2018 at 9:11 pm
    Unfortunately, that doesn’t work either. I’ve tried a new comp, new project, restart, etc.
