Activity › Forums › Adobe After Effects › Glitch when using Deblur
  • Chris Jordan
    August 8, 2018 at 9:12 pm
    “should have just done the obvious and rendered and imported that video clip”
    It’s not obvious because you need warp stabilizer to analyze the clip so that it can calculate the deblur, if you render with warp and then reimport and try to deblur you’d need to add another instance of warp stabilizer.
  • Michael Szalapski
    August 9, 2018 at 1:58 pm
    [Chris Jordan] “you need warp stabilizer to analyze the clip so that it can calculate the deblur, if you render with warp and then reimport and try to deblur you’d need to add another instance of warp stabilizer.”
    Camera Shake Deblur doesn’t need to work in concert with Warp Stabilizer. You can run it on a pre-rendered clip.
    – The Great Szalam
    (The \’Great\’ stands for \’Not So Great, in fact, Extremely Humble\’)
  • Chris Jordan
    August 9, 2018 at 9:32 pm
    So I tried pre-rendering with warp and then reimporting and adding deblur the blur banner glitch is now gone, but now there’s another glitch that looks like black holes/tears in the image: https://imgur.com/a/lQU2j6f
    Is the deblur effect in beta or something?
    View post on imgur.com
  • Richard Garabedain
    August 9, 2018 at 9:54 pm
    Honestly From the get go I had no idea what you were talking about. Never heard of DeBlur before…but i can guess what it does
  • Chris Jordan
    August 9, 2018 at 10:18 pm
    Yeah I didn’t either before searching for a solution to a really bad motion blur problem. I was wrong about needing warp stabilizer on it before the effect, I was watching tutorials and all of them used warp in conjunction with deblur and swore one of them said you needed warp on it for it to work. Deblur works decently, when it actually works lol.
Page 2 of 2
