Activity Forums Panasonic Cameras gh5 vlog to rec 709 lut test
  • Duke Sweden
    September 25, 2017 at 11:17 pm
    Hey Chris, just an update. Still waiting for firmware 2.0. Saturday is the latest we should get it but I’ve read that Panasonic “Luminaries” are planning events for this weekend around the upgrade so it could be Thursday or Friday.
    Also, just to wrap things up, my transition problem turned to be that Resolve, unlike Premiere Pro, won’t let you drop a transition between clips if there isn’t any extra footage at the end or beginning of a clip, whereas PPro will let you do a transition but it warns that it will repeat frames.
    Dell XPS 8920
    Intel i7 core 7700 build
    GeForce GTX 1050ti
    32 Gigs of RAM
    3 7200 RPM SATA Drives
    Windows 10 64-bit
    Premiere Pro CC 2017 v.11.0
  • Ole Kristiansen
    September 26, 2017 at 6:03 pm
    Hi Duke
    “For some reason only certain clips won’t let me add transitions.”
    In Davinci resolve, you can select a clip – hold Shift + ALT and then drag the clip over another clip – thereby creating a Cross Dissolve automatically – In the Inspector you can then choose another transition.
  • Duke Sweden
    September 27, 2017 at 9:43 am
    Thanks, Ole, but I found the problem. Unlike Premiere Pro, if you don’t have excess footage you’ve trimmed from the beginning and/or end of clips, Resolve won’t let you create a transition. In PPro, you still can but it will use the last frame and beginning frame, causing a bit of a freeze frame effect. When I trimmed a clip, then Resolve let me drop transitions between the clips.
    But thanks anyway!
    btw, just got firmware update 2.0 for the GH5. I’ll be uploading short clips here later today for people to play with, as Chris Wright requested.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Chris Wright
    September 27, 2017 at 12:01 pm
    sweet!
  • Duke Sweden
    September 27, 2017 at 1:19 pm
    Hey Chris, in order to make the clips useable for you let me know what you’d like. V Log or HLG. Properly exposed or dark. Indoor or out. I will keep the clips at around 3-5 seconds since they’re huge at 400mb’s.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Chris Wright
    September 27, 2017 at 1:37 pm
    vlog, good exposure, large dynamic range, outside, single still image PNG, trillions of colors or if not possible, millions of colors 🙂
  • Duke Sweden
    September 27, 2017 at 3:00 pm
    Really? A png file will hold all the data you need to experiment with 400mb’s of data? OK, coming up.
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    September 27, 2017 at 3:30 pm
    Here ya go. V Log, 4096×2160, 400mb’s, All-I
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Duke Sweden
    September 27, 2017 at 4:23 pm
    Hey Chris, could you do me a favor and post the results of your tweaking here? I figure if the pumpkin shows up as purple on my monitor I’ve got some adjusting to do 😉
    Dell XPS 8920
    GeForce GTX 1050ti
    32 Gigs of RAM
    Windows 10 64-bit
  • Chris Wright
    September 28, 2017 at 12:14 am
    I tested it with the gh5 neutral 2% raised blacks. I fiddled around and couldn’t get better settings from the xmp than I had before. But wow! the all-i has beautiful highlight rolloff now. just check out the reflection of the sun off the wood railings and the leaves. no more ugly dlsr clipping. man, that lut sure loves that camera.
Page 5 of 6
