Activity Forums Maxon Cinema 4D Get MoGraph clones to stick to Thinking Particles
  • Get MoGraph clones to stick to Thinking Particles
    Posted by Jedidiah Hurt on January 16, 2010 at 11:26 pm
    If I have 1000 thinking particles (controlled by PWind, for example) and 1000 clones of an object created with MoGraph’s cloner object, is there any way to assign the position of each clone to the position of each thinking particle?
    Adam Trachtenberg replied 16 years, 7 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    January 17, 2010 at 6:32 am
    You just have to set your cloner to object mode and then drag your thinking particles group into the cloner’s object box. So if you’re using the default TP “All” group, open Objects>Thinking Particles>Thinking Particles Settings and drag the particle group “All” into the Cloner Object>Object>Object box.
