Activity Forums Apple Final Cut Pro Legacy Full screen preview not working
  • Full screen preview not working
    Posted by Adam Sylvester on May 13, 2008 at 4:02 pm
    I’m trying to do a full screen preview on my secondary monitor. I’ve selected the proper monitor and use CMD-F12 to select all frames. However, the playback only displays the first frame. If I pause it and restart, it will display the frame I paused on. I have tried deleting my plist file and still nothing. Any ideas?
    Adam
    Drew Rosas replied 16 years, 10 months ago 4 Members · 5 Replies
  • Shane Ross
    May 13, 2008 at 5:15 pm
    VIEW>EXTERNAL VIDEO>ALL FRAMES. make sure that is chosen.
    Shane
    GETTING ORGANIZED WITH FINAL CUT PRO DVD now for sale!
    http://www.LFHD.net
    Read my blog!
  • Adam Sylvester
    May 13, 2008 at 5:17 pm
    Unfortunately I’ve already tried that as well.
    Adam
  • Kevin Monahan
    May 14, 2008 at 12:26 am
    It definitely has to do with your View menu settings.
    How about View > Video Playback > Digital Video Desktop. Tried that?
    Either that or do the “quit FCP > trash prefs > reboot > repair permissions > launch FCP > ensure View menu is set up correctly” boogie.
    Throwing a little salt over your shoulder helps too.
    Kevin Monahan
    http://www.fcpworld.com
    Author – Motion Graphics and Effects in Final Cut Pro
  • Adam Sylvester
    May 14, 2008 at 9:24 pm
    Still nothing. I’ve even tried reinstalling the entire suite after following Apple’s instructions to delete the previous install. It doesn’t matter what device I select or if I have one or two monitors attached to my screen. It worked fine when I had a MacBook Pro but when I switched to a MacPro everything stopped working.
    Adam
  • Drew Rosas
    August 27, 2009 at 9:02 am
    Not sure if you got this yet but I had the same problem and fixed it by going to
    Final Cut Pro/ Audio Video Settings/ A/V Devices
    Then De-selecting Mirror on Desktop.
    Now simply use Command – F12
    Hope this works.
    Drew
