Activity › Forums › Apple Final Cut Pro Legacy › frutration sensation: FCP not seeing ALA Io LA since Studio 2 upgrade
  • frutration sensation: FCP not seeing ALA Io LA since Studio 2 upgrade
    Posted by E. Eric johnson iii on June 28, 2007 at 7:08 pm
    i rarely use my IoLA, but have reason to now and, since upgrading to FCS2, i cannot get the log & capture window to see video or audio. i have been through the all of the settings, all lights on the unit indicate everything’s a go.
    the Io Control Panel says there’s “no video” even tho’, as stated before, the indicator lights on the unit say otherwise.
    i have gone through every possible setting and, other than machine control, nothing else is working.
    have there been some changes in FCS2 that have brought this on?
    i’m tempted to get an A/D converter & just do it through my KONA 2 card (i have a video component SDI converter available to me)
    arrrrggghhh… i’m going insane.
    e. eric johnson iii
    eric@lillmonster.net
    LILL MONSTER MOTION PICTURES
    producer-director-camera
    now in principal photography – START 2 FINISH: What It Really Takes to Race A Bike
    Pat Defilippo replied 19 years, 3 months ago 7 Members · 12 Replies
  • 12 Replies
  • David Roth weiss
    June 28, 2007 at 7:16 pm
    Did you upgrade to the latest version of the Kona drivers??? If not, then uninstall the current drivers as recommended and install the new ones, that will most likely solve your problem.
    “No job is worth doing more than once…”
    David Roth Weiss
    Director/Editor/Post-production Supervisor
    David Weiss Productions, Inc.
    Los Angeles
  • Shane Ross
    June 28, 2007 at 7:18 pm
    Do the KONA drivers work for the I/O LA…since it is NOT a KONA card?
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Lee Berger
    June 28, 2007 at 7:19 pm
    Try cycling the LA’s power off and on.
    Lee Berger
    http://www.leebergermedia.com
  • David Roth weiss
    June 28, 2007 at 7:52 pm
    [Shane Ross] “Do the KONA drivers work for the I/O LA…since it is NOT a KONA card?”
    It still requires drivers from AJA, but apparently there is no update since the Universal Binary was released last year. Nonetheless, I would think unistalling and reinstalling the drivers would probably do the trick.
    David Roth Weiss
    Los Angeles
  • E. Eric johnson iii
    June 28, 2007 at 7:58 pm
    hi everybody-
    thank you for the quick replies… my sanity is grateful.
    i have the latest KONA drivers, but that doesn’t get me my A/D audio… unless i’m missing something… which is entirely possible.
    what i ended-up doing is just pulling my IoLA from my G5 and hooking it up to my 15″ powerbook and voila! it works like butter. i have an older version of FCP loaded on the powerbook so it was happy. fortunately it’s a betacam to DV conversion so i’m not getting killed on throughput.
    i guess from here on, non-SDI goes the powerbook route.
    again thank you & glory to the cow!
    eric
    e. eric johnson iii
    June 28, 2007 at 8:46 pm
    i have a psuedo-related question on this topic…
    will this problem go away if one were to own the HD I/o?
    it is my understanding the HD Io is all things HD/SD – digital/analog, so in theory that is correct isn’t it?
    eric
    e. eric johnson iii
  • Shane Ross
    June 28, 2007 at 8:52 pm
    The I/O HD doesn’t do uncompressed HD, it captures as ProRes 422. But it will do all forms of HD, and I think it will do DVCPRO HD too. But it can’t du UC HD because it connects via firewire 800.
    DARN Sweet though. ProRes 422 is nearly indistinguishable from uncompressed HD.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Dave Jenkins
    June 28, 2007 at 8:57 pm
    We are using our AJA LA with Studio 2 with no problems. It didn’t require new drivers, the latest for the LA work fine. Io Driver V3 for Io/IoLA/IoLD (Release Date 4/4/2006). We are on a G5 Dual 2 Gig. OSX 10.4.9. I would call AJA Tech Support.
  • Jeremy Garchow
    June 28, 2007 at 11:02 pm
    You must download and install the io drivers, they are not the same as the Kona drivers.
    Do an uninstall then a reinstall of the io drivers.
    https://www.aja.com/ajashare/AJA_Io_v3.0.zip
    Jeremy
    June 28, 2007 at 11:39 pm
    no UC HD w/HDiO… bummer. i haven’t had a chance to look at the specs in detail as of yet. but not having UCHD lowers the drool factor just a little.
    i’ll check with aja on the IoLA with the G5…
    thanks everybody… glory to the cow.
    eric
    e. eric johnson iii
