Activity Forums VEGAS Pro Frequent Crashes in Sony Vegas Pro 10 e
  • Frequent Crashes in Sony Vegas Pro 10 e
    Posted by Alex Jarvis on July 31, 2011 at 10:52 pm
    When working on my current project, I am getting these errors:
    Problem Description
    Application Name: Vegas Pro
    Application Version: Version 10.0e (Build 738) 64-bit
    Problem: Unmanaged Exception (0xc0000005)
    Fault Module: C:Program FilesSonyVegas Pro 10.0vegas100k.dll
    Fault Address: 0x000000018015A361
    Fault Offset: 0x000000000015A361
    Fault Process Details
    Process Path: C:Program FilesSonyVegas Pro 10.0vegas100.exe
    Process Version: Version 10.0e (Build 738) 64-bit
    Process Description: Vegas Pro
    Process Image Date: 2011-06-29 (Wed Jun 29) 16:33:50
    Problem Description
    Fault Module: C:Windowssystem32ntdll.dll
    Fault Address: 0x0000000077470D2B
    Fault Offset: 0x0000000000080D2B
    Problem Event Name: APPCRASH
    Application Name: vegas100.exe
    Application Version: 10.0.0.738
    Application Timestamp: 4e0a4fd7
    Fault Module Name: StackHash_9516
    Fault Module Version: 6.0.6002.18327
    Fault Module Timestamp: 4cb74dd3
    Exception Code: c0000374
    Exception Offset: 00000000000aca57
    OS Version: 6.0.6002.2.2.0.768.3
    Locale ID: 1033
    Additional Information 1: 9516
    Additional Information 2: 90044fdc79b06df4dbe52922b8651428
    Additional Information 3: 8a84
    Additional Information 4: 7d7450505e8764ce6fe71402db733d7f
    And here are my system specs:
    Intel i7 920 @ 2.67 ghz
    RAM: 9 GB
    Windows Vista 64-bit
    700GB HD
    This seems to happen more when the project is large, i.e. alot of different media and effects. I’m not sure Vegas is capable of handling a lot of effects and I am thinking of moving back to Premiere. But I just want to be sure it isn’t something that only requires a setting be changed or something else simple. I have also contacted Sony support.
    Any help would be appreciated.
    Thanks in advance.
    Dave Lozinski replied 15 years ago 2 Members · 1 Reply
  • Dave Lozinski
    August 3, 2011 at 8:06 am
    Try this: delete all the files from (make a backup copy first somewhere just in case) :
    C:\Documents and Settings\user\Application Data\Sony\File Templates\aviplug
    Also, how much free space do you have on your C drive? If C drive were to be running low, this could happen.
    Let us know how you go.
    https://www.davelozinski.com
    https://www.davelozinski.com/DemoReel/
