Activity › Forums › DaVinci Resolve › for sale : Xrite Hubble and Xrite i1 Pro
  • for sale : Xrite Hubble and Xrite i1 Pro
    Posted by Michael Cinquin on October 20, 2011 at 8:41 am
    Hi
    I’m selling my Xrite Hubble —privately owned— (aka Sencore OCT1000), for 1850 €. It comes with its genuine usb cable, its metal carrying case, and i1 Display Manager to make internal calibration tables.
    I’m also selling my Xrite i1 pro —privately owned— for 550 €, with its case full of accessories (beamer holder, white calibration tile, scan target, etc…). Eye One Match is included, comes with LCD, CRT and Beamer modules.
    The probes and I live in Belgium.
    Drop me a mail if you’re interested (mc@michaelcinquin.com)
    Michael Cinquin
    Final Cut Pro – Avid Media Composer editor
    DaVinci – Color – Baselight colorist
    Color profiles for Color
    http://www.michaelcinquin.com/tools : tools for FCP | Color | RED | subtitles | Cinema Tools | Timecode – Keycode calculator
    Michael Cinquin replied 14 years, 9 months ago 6 Members · 22 Replies
  • 22 Replies
  • Mikhail Puzyrev
    October 20, 2011 at 11:09 am
    Hello Michael! Did you find that a human eye is more precise tool? Or you going to quit color grading forever for something more interesting? ))
  • Michael Cinquin
    October 20, 2011 at 11:19 am
    Hi Mikhail
    nice to read you.
    well I did buy an FSI monitor (which cannot be calibrated by the end user), and also I’m buying a new projector ProjectionDesign, (which is supposed to come hardware-calibrated), and whose white point I can adjust by comparing to the FSI.
    And I need the cash to open a second office in the other region of Belgium (Wallonia).
    And I found where I can rent a CS-2000 😉 (scientec.fr)
  • Jake Blackstone
    October 20, 2011 at 8:05 pm
    What do you mean by “FSI monitor (which cannot be calibrated by the end user)”?
    Of coarse it can be calibrated, just like any other type of LCD monitor…
  • Michael Cinquin
    October 21, 2011 at 8:04 am
    Well, you sure can adujst white point, saturation, brightness, chroma, luminosity. But you can’t tweak the CMS nor the grayscale balance without renting the calibration kit from FSI, and they don’t rent outside the US.
  • Clayton Burkhart
    October 21, 2011 at 11:03 am
    Pointless to calibrate for the color on the FSI, that remains relatively stable over time. Aside from a 20K calibrator, you are likely to make things worse with a calibration unit rather than better for a video monitor. Mostly it’s the brightness levels which diminish. If you measure only the luminance from the moment of purchase you will be able to see the drift over time, provided you use the same tool and lighting conditions. This you can adjust manually on the screen, remeasuring until you arrive at your original values. Leave the serious calibration to the big boys.
  • Jake Blackstone
    October 21, 2011 at 11:16 pm
    The point was made, that FSI monitor “which cannot be calibrated by the end user” is completely wrong. Any professional monitor, including FSI can be calibrated with the right tools.
  • Michael Cinquin
    October 22, 2011 at 7:37 am
    so as not to infuriate M. Blackstone, and for the sake of completeness, let’s change
    into
    “which cannot be calibrated by the end user unless she owns (or rent inside the USA) FSI’s calibration kit
  • Robin Erard
    October 22, 2011 at 7:41 am
    Certains membres de ce forum sont un peu chiants parfois.
    Peux-tu m’en dire plus sur le projectordesign, prends-tu un projecteur avec lampe xéon ? Toujours dans un espace REC709 ou DCI.
    A plus
    Robin
    réalisateur, scénariste, monteur, étalonneur
    http://www.robinerard.ch
  • Jake Blackstone
    October 22, 2011 at 6:37 pm
    You absolutely CAN calibrate the FSI monitor, just like any other monitor with number of available hardware options from Klein or Minolta and can create a profile LUT in order to build a viewing or print LUT with something like Cinespace or Light Illusion for use with all software offerings, like DaVinci, Image Systems, Autodesk etc..
    People are buying this monitor outside of US and they are able to calibrate it themselves, without need to send it back to US for calibration at the factory.
  • Michael Cinquin
    October 22, 2011 at 7:32 pm
    [jake blackstone] “You absolutely CAN calibrate the FSI monitor…
    You sure can profile your FSI monitor with whatever probe you have, then build a LUT with whatever software you have, then use whatever software or hardware to apply the lut, and you’re free to call the result “calibrated”. Of course that will not change the internal settings of the FSI, it will merely put a LUT in top of the internal LUT of the monitor.
Page 1 of 3
